Gear ratio
Old Sep 27, 2020 | 06:25 PM
96 OBS's Avatar
96 OBS
Gear ratio
I know there’s bunch of threads on this but I have a couple issues. My driver door was swapped with another truck so I can’t get the axle number. Truck is a 1996 f-350 with a ZF5
at 65 in 5th I’m at 2000 rpm
can anyone give me ideas on what rear end ratio I have? I have 285/75 tires all around so my speedo is slightly off but not much. I think 65 on the speedo is actually like 67 or something like that
Old Sep 27, 2020 | 06:41 PM
Edgethis's Avatar
Edgethis
Have you checked the diff for a tag?
Old Sep 27, 2020 | 06:55 PM
96 OBS's Avatar
96 OBS
I thought of that. Do they have the axle code or the ratio on it?
Old Sep 27, 2020 | 06:56 PM
Edgethis's Avatar
Edgethis
Should be a combo. It usually indicates stock ratio and if it was limited slip.
Here's a site thats been linked before. Shows my diff as a 3.55 Limited slip. Not sure thats accurate lol.
Decodibg ford axle tags
Old Sep 27, 2020 | 07:21 PM
96 OBS's Avatar
96 OBS
Alright there is no tag to be found. Front back top bottom. Unless I’m just blind as heck lol
Old Sep 27, 2020 | 08:13 PM
z31freakify's Avatar
z31freakify
You probably have 4.10 judging that I have 3.55 and 305 55 20( 33") I run 2000 rpm at 75mph
One way to check is to mark one of your drums and back plate and pinion yoll to diff housing then turn the yolk by hand and see how many turns it took to do a complete turn om the drum if it turned 3.5 turns you have 3.55 if it took 4.turns 4.10. Pretty accurate in telling what gear you have and a good way to find gear rations on axels.
Old Sep 27, 2020 | 08:16 PM
97-psd's Avatar
97-psd
Probably 3.55 gears. Your description is pretty close to how mine behaves at similar speeds. I am also running 285s
Old Sep 27, 2020 | 08:23 PM
z31freakify
Oh snap he has 5 spd. Ignore my 4.10 gear answer.
Old Sep 27, 2020 | 08:35 PM
96 OBS's Avatar
96 OBS
Yes sir 5 spd. I’ll do that rotation check tho. Someone told me about that a long time ago I couldn’t quite remember how exactly to do it. Thank fellas!
Old Sep 28, 2020 | 08:54 PM
carl2591's Avatar
carl2591
just for reference on my 03 auto with 3:73 rear end.. at 2K the speed is 70 mph..
Old Sep 29, 2020 | 09:36 PM
Minnesota_Duane's Avatar
Minnesota_Duane
65 mph
3.55 rear ratio
28.11 inch tires
.76 Overdrive ratio
2,097 RPM
Old Sep 30, 2020 | 02:08 AM
Kingkong0192's Avatar
Kingkong0192
Just pop the diff cover and read the numbers off the carrier.
You can change the gear oil in the rear diff at the same time and it'll be a win-win.
Old Sep 30, 2020 | 08:44 AM
Hit Man X's Avatar
Hit Man X
Thumbs up
Sounds like a 3.55:1 truck.
The dually does 2500rpm at 70mph on 245/75R16s in 5th gear. It has 4.10:1 gears.
Old Oct 1, 2020 | 08:39 AM
96 OBS's Avatar
96 OBS
Good info thanks guys!
mezapu
Sep 20, 2022 04:55 PM
Jayme Duty
Aug 6, 2011 12:00 PM
mclarengts
20
Mar 1, 2010 11:56 AM
ammo troop
1983 - 2012 Ranger & B-Series
Jul 31, 2004 05:01 PM
