what brand 02 sensor?
Old Sep 26, 2020 | 11:56 AM
turbocoupe88's Avatar
turbocoupe88
Trailering
well installed a new bosch supposedly oem replacement 02 and crapped out within 2 weeks
anyone try denso or ntk seems like bosch are not made like they used to be
thanks for any info
Old Sep 26, 2020 | 01:39 PM
diggerrigger's Avatar
diggerrigger
Good to hear... not. I just installed a Bosch 11027 on mine last Sunday. Guess I should get another week out of it. Bosch was my go to brand. I'll be watching for recommendations.
Old Sep 26, 2020 | 02:38 PM
JJF20's Avatar
JJF20
I’ve had good luck with Denso.
Old Sep 26, 2020 | 06:16 PM
My4Fordtrucks's Avatar
My4Fordtrucks
I use NTK when available.
Old Sep 26, 2020 | 06:25 PM
00t444e's Avatar
00t444e
NTK is good they are an OEM supplier.
Old Sep 26, 2020 | 07:09 PM
R&RFord's Avatar
R&RFord
you should check the harness before you replace the sensor again.
Old Sep 27, 2020 | 04:42 PM
My4Fordtrucks
Every oxygen sensor I have removed from my Ford vehicles has been an NTK.
Old Sep 28, 2020 | 01:29 AM
TexasGuy001's Avatar
TexasGuy001
Odd, I have had no issues with Bosch. And all of my 3 9th gens look to have come factory with them. I have replaced them every so many years/miiles as maintenance but thats it. Maybe there is a wiring issue.
Old Sep 28, 2020 | 06:17 AM
Chip Schweiss's Avatar
Chip Schweiss
There are a lot of counterfeit parts out there. Bosch, Motorcraft, NGK are big targets of the fakes. If you bought it on Amazon or eBay, I would be suspicious. None of the manufacturers do much to combat the problem which is a problem for their own reputation.
Do some Googling about it and you will find people showing how to identify the fakes.
Old Sep 28, 2020 | 03:42 PM
diggerrigger
Not sure if my just purchased Bosch was bad right out of the box, is bad or is good and I have another problem. Voltage is stuck on .75 v.
Old Sep 28, 2020 | 03:50 PM
ford390gashog's Avatar
ford390gashog
Any Bosch part laser marked with a "C" in a circle is their ultra value jobber line. Its all PRC/Mexico in origin, the parts are easy to spot.
Old Sep 30, 2020 | 02:42 AM
TexasGuy001
Interesting. Something to watch for. Guess C stands for cheap.
KodiakF250
6.7L Power Stroke Diesel
May 25, 2018 11:33 PM
comtb
Dec 31, 2016 02:59 PM
bryyce62
Sep 20, 2011 01:08 PM
cjben
May 24, 2009 10:25 PM
belle3006
Oct 23, 2007 11:07 AM
