Sponsored by: Auxito
Replacement light switch
Old Sep 23, 2020 | 09:40 AM
JOE SKI's Avatar
JOE SKI
My 97 Lariat has a dimmer switch for autolamps besides the one for dash lights, headlight, fog light etc. Has anyone replaced it with one not having the autolamp dimmer? Are they the same size? Will the plugs fit? Thank you
Old Sep 23, 2020 | 12:51 PM
projectSHO89's Avatar
projectSHO89
That's actually your exit delay setting. It determines how long the lights stay on after you get out of the truck.
Old Sep 23, 2020 | 03:37 PM
JOE SKI's Avatar
JOE SKI
ok thanks. I just got one fromm a used trucck w/o the autolamp and it is a direct replacement. It didn't fix my problem though-at night the headlights go out. If I turrn on the high beams on the multi-funcction switch and then turn them off the low beams will come back on for a short while but eventually go off again. I guess I need a new multi-function sw or headlight relay? Any suggestions?
Old Sep 26, 2020 | 11:44 PM
newfordy's Avatar
newfordy
Joe Ski, do you only have the headlight problem at night, or is that the only time you use headlights? I use low beams whenever I get on the highway.
On my '01 the headlights would not shut off at times, flicker while on, or not go on without cycling the switch. They would even go on with light switch and ignition in off position.
Replaced the switch, problem solved.
Since you have a used replacement switch, could be your problem.
wwchatt
Apr 7, 2018 11:58 AM
HRTKD
All Things Towing
Dec 31, 2016 07:25 PM
oracle
Apr 28, 2013 10:23 AM
Downriver Thunder
Nov 5, 2009 06:17 PM
desperado_18_2000
Apr 3, 2003 11:38 PM
