Sponsored by: Real Truck
frot grille
Old Oct 21, 2003 | 05:07 PM
user 708242442's Avatar
user 708242442
frot grille
How do I remove the front grille?
Old Oct 21, 2003 | 08:13 PM
Powerstroke_wannabe's Avatar
Powerstroke_wannabe
Assuming your front grille installation is the same as my 2000 SD, it's pretty easy. The grille is held in by two clips at the bottom and several screws at the top. Just look between the top of the bumper and the bottom of the grille and you should see the clips. Use a screw driver to unclip the bottom two clips. The screws are at the very top of the grille, just under the hood. Remove the screws and you're done. Off comes the grille in less than 5 minutes.
Old Oct 22, 2003 | 04:07 PM
user 708242442
Thanks for the info. someone zip tied my plug for the block heater to the back of the fog lights. snow coming tonight so I thought I'd locate the plug.
Old Oct 22, 2003 | 05:11 PM
jdadamsjr's Avatar
jdadamsjr
If you're 03 is like my '03 Ex there's about 5 clips, but just as easily removed...
quick tip... when putting grill back on remove clpis from truck and prefit on grill - then push clips into slots, MUCH easier that way !
