Front Grille
Old Oct 21, 2003 | 05:05 PM
user 708242442's Avatar
user 708242442
Front Grille
How do I remove it? The plug for my block heater is zip tied to my fog light and I can't get it out.
Old Oct 21, 2003 | 07:42 PM
ALASKAF250's Avatar
ALASKAF250
I had a hell of a time too. But a long set of snips cured it.
Old Oct 21, 2003 | 09:48 PM
mbnv992's Avatar
mbnv992
I've yet to find mine (didn't bother looking for it yet) Hopefully mine won't be hidden that far in.
Old Oct 22, 2003 | 12:22 AM
mikewrt's Avatar
mikewrt
I still can't find mine, I'm sure it has one on it but where it is at I don't know?
Old Oct 22, 2003 | 07:04 AM
Emil's Avatar
Emil
Behind the bumper on the passenger side by the tow hook.
Old Oct 22, 2003 | 10:09 AM
jdadamsjr's Avatar
jdadamsjr
The heater pigtail is just a figament of your imagination...
BigFoot has been seen more times than it
Actually, I couldn't find mine on the '03 Ex until I pulled the grill...
(Not too hard once you know how ! -
five screws on top, four or five clips on bottom... Used a long screw driver to push up on the bottom of the u shaped clips to pull them out)
Reinstall tip: pull clips off truck and put on grill to put grill back on - much easier !)
on MY Ex the black block heater three hole receptacle with the small cover was zip tied to the wire loom running down just in front of the radiator on the PASSENGER side... it was pointing down so very hard to see... Could not see it from the bottom or the front until I knew where it was...
Will have to post some pics !
This is a common complaint for a lot of folks !
"Ware is it !?!"
hope this helps!
Old Oct 23, 2003 | 04:13 PM
user 708242442
Hey thanks for the info. The grille comes off farly easy. Why do they tie it back like that?It would of sucked if I really needed it.
Old Oct 23, 2003 | 05:34 PM
jdadamsjr's Avatar
jdadamsjr
They tie it out of the way so we can have LONG threads and many afternoons under our trucks to 'get to know them' while looking for it
And could you see the line at the dealership complaining about the banging going on in the front end if they didn't tie it down ?
Old Oct 26, 2003 | 12:52 PM
Haakeyez50's Avatar
Haakeyez50
Haakeye wrote:
I drilled and put my block heater conection in my bumper along left side crome covered plug. keep a short cord under back seat when i need it i plug it in. should have pics in webshots.
Old Jan 12, 2008 | 06:35 PM
fireexplorere's Avatar
fireexplorere
Question How Do I remove My grille from my 1997 F150?
I need some help I just got this black 1997 F150 4X4 and I need to remove the grille to paint it and install some strobe lights on it. I'm a Vol. FireFighter and I need to get this done. Anyone how do I remove the grille? please help...
Sincerly, Travis Miller
Waterloo Fire Rescue
