Driver / passenger Door Step
Old Sep 22, 2020 | 03:54 PM
old28's Avatar
old28
Has anyone installed a door step or door step loop on a early 70's Ford F250?
I know it will not look correct but medical conditions call for one being installed on my 1971 F250 so I can continue to drive it. I have looked at the Bully style U loop type as one idea, any others that you guys have tried.
Old Sep 23, 2020 | 09:46 PM
old28's Avatar
old28
Come on guys, someone got to have mounted one. The Bully AS-200 is one I have looked at. It comes in polished aluminum & I would like one in black. Might even paint it a blue so it goes with my body color even if it is a darker blue.
Old Sep 23, 2020 | 09:50 PM
JEFFFAFA's Avatar
JEFFFAFA
Sorry I can't help. I have not done it. Are you good at fab work?
Old Sep 23, 2020 | 10:18 PM
cstoyer's Avatar
cstoyer
I would look at these.
https://bullyusa.com/side-steps-alum...or-trucks.html
May need a little fab but very traditional
CStoyer
Old Sep 23, 2020 | 10:22 PM
1browski's Avatar
1browski
I have never used or mounted one but a 1970 f350 cab and chassis that I have has one. I think its pretty cheesy but it might be a 1970 special.
I didnt really look at it much since this is just for extra parts and I paid no attention to how it attaches. I would pull it off and put up pictures for you but it is about 45 minutes to an hour from my house. Im sure there is probably better options out there that will work and look right on your truck.
Old Sep 24, 2020 | 11:06 AM
old28's Avatar
old28
JEFFFAFA-- I'm OK at fabing but short on welding equipment these days.
cstoyer-- These were the Bully hoops I was looking at.
1browski-- Thanks for the reply
Old Sep 24, 2020 | 11:23 PM
cbrown9064's Avatar
cbrown9064
Like this?
I can measure or take a pic tomorrow if you are interested. Cut some spacers out of 3/16 flat stock, used 4 spacers per step (3/8” total) And mounted To the door sill horizontally. It was easy.
Old Sep 25, 2020 | 12:14 PM
old28's Avatar
old28
cbrown9064 -- Ya like that, I ordered a pair in black aluminum, I will see about spacers when I get them.
Question, did you mount them even with the front of the seat on the sill?
Old Sep 27, 2020 | 08:02 PM
cbrown9064's Avatar
cbrown9064
Here are a couple pictures. The step is mounted as far forward as possible underneath. You can see the right side is snug against the "bulge" on the forward side of the door sill.
I had them farther back, like in line with front edge of seat and that didn't allow you to swing your back leg in easily. I only use them about 10% of the time, easier to grab the wheel and hoist. And mine is 4wd with 35s...
Old Sep 28, 2020 | 12:32 PM
old28's Avatar
old28
cbrown9064 -- Thanks for the step mounting pictures and placement comments. I will mount mine as far forward as I can, that will help a person getting into the passenger side. I will see about spacers when I get the steps later this week. Looks like the two bolts hold them solid.
vans
Aug 30, 2019 05:05 AM
1972washington
Jul 22, 2013 10:15 AM
netprformer1
1997 - 2003 F150
Sep 8, 2002 08:16 PM
