Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
got heat?
Old Feb 11, 2004 | 12:55 PM
  #31
gasman6674's Avatar
gasman6674
Eric If you will email me the following info I will run a "heat loss" on each room
Size, ceiling ht, construction (wood/block etc), Insulation amount, and number size and type of openings (windows/doors)
If you have the ceiling ht you might be able to use low intensity gas fired radant heat. Very clean very simple.
Regards
Old Feb 11, 2004 | 02:37 PM
  #32
72stepside's Avatar
72stepside
I love Florida
Old Feb 12, 2004 | 12:03 PM
  #33
Phillippio's Avatar
Phillippio
Got Heat? I have a little 1000 watt space heater. It is more than enough for my shop.
The more appropriate question for Tucson is "Got AC?" I have a swamp cooler and a small AC unit for my shop. The heat is still brutal in the middle of the summer.
Old Feb 16, 2004 | 10:52 PM
  #34
Peter94's Avatar
Peter94
freind of mine has an old heater in his garage, its a wood burner, we got it up to about 95 degrees inside, when it was about 0 degrees outside, man it was nice, we actually had to open the door for a second cause we were sweating.
SasquatchZilla
Oregon Chapter
13
Jan 21, 2012 01:32 PM
Aftrmidnite
Garage & Workshop
May 7, 2010 10:42 PM
Primered86XLT
Garage & Workshop
21
Sep 4, 2005 05:36 PM
kc2006
Garage & Workshop
Jan 24, 2005 02:20 PM
zuikoman
Garage & Workshop
25
Jan 19, 2005 05:26 PM
