Help with 5th wheel towing
It would appear to me that your max 5th wheels is 15.5K. Lots of other numbers have todo with ttrailers that have either a weight distribution or no distribution off of your receiver.
So first things first. Get your truck on the catscale and see what the weights are per axle. Then technically you can add the two (ticket will have done this) and then review that number with what the yellow sticker indicates. Subtract and then you have the avail payload. Not an accurate enforceable number and likely won't be a lot of room.
Using the white stick axle ratings is a more accurate and enforceable number. A catsscale gives you those numbers so just subtract the mainly rear gross rating. Difference is what you can have for payload.
a 5th wheels king pin wt is what goes in the bed of the truck and becomes payload. The other important and enforceable number is the max tire load at max psi. So don't exceed either.
So when looking at trailers, other than floor plans and features, first look at the while sticker on the 5er. Take the GVW and then 20% of that will be the king pin wt. Lots of 5er's will advertise a king pin wt that is inaccurate once it leaves the factory. Go by the sticker.
So knowing your payload and knowing the 20% king pin wt will help you to decide and 5th wheel no more than about 15K lbs.
You can also go to fleetford.com and look at the towing guide for your year for the numbers.
If you have a toy hauler model, the pin weight can be much higher, as they are often built to hit about 20% when loaded. That means that they are pin heavy when not loaded, so that loading a heavy “toy” doesn’t take too much weight off the pin.
If you find that your 250 doesn’t have enough payload capacity, you might look at a similar floor plan in a bumper pull. You’ll normally run out of payload capacity long before you run out of towing capacity. By their nature, bumper pulls have less weight on the nose, so they don’t hit you as hard on your available payload.
Towing guide
Denny
Truck: 2018 F250 CCSB Lariat 4x4 6.2 (gasser). Payload: 2849
Trailer: 2016 Surveyor 275BHSS (Classified as 1/2 ton towable). Dry 7404, dry pin 1140, GVWR 9943, Loaded weight 8200-8300, loaded pin 1700-1800.
Payload in truck aside from the pin: Wife, kids, dogs, fiver hitch, tonneau cover, tools, etc.... Approx. 1000 lbs. (8025 on the scale).
Between what I normally carry, and the extremely lightweight loaded pin weight of my '1/2 ton towable' fiver, I'm essentially maxing out my 3/4 ton's payload. If I had a heavier diesel, I'd be way over my payload.
So yes, 3/4 tons CAN tow fivers, but realisitically, they can only tow really specific fivers, with really specific setups, to still be within their numbers. Most fivers, especially if you're looking at 15000 lb fivers, are going to exceed the numbers of a 3/4 ton.
Denny
Drive axle is your rear wheels.
Trailer is what is over those axles.
b
This I loaded weight with your TT. So what it does not tell you is the unloaded weight. That is what you need for the 5er calculations.
Based upon what I see, your rear axle has a RAGWR of probably 7K, unloaded is probably 3200 lbs. front is probably what is listed on your sheet or close to it.
b
My father had a 11,000 GVWR bumper pull toy hauler. He just bought a new RZR that didn't fit in his existing toy hauler. He has a 2019 F-250 Crew Cab Short Bed. He just picked up a Vengeance Rogue Armored 4007. It's GVWR is 17,065. I'm telling you that that big ole 5th wheel tows so much better than that bumper pull its not even close. Its like night and day difference. It is so much more comfortable towing it than the bumper pull and all we did to my father's truck was install Stableloads. And yes, my father had a weight distribution hitch for that bumper pull toy hauler...
My 2 cents...
My 2 cents...
15,000 lb fiver is likely on the long side. My preference is to go a little lighter and shorter. Can get a lot of camper 12,000ish lbs and under.
