PullRite Super Glide hitch problem--SOLVED
Old Sep 20, 2020 | 09:00 PM
ForBruce's Avatar
ForBruce
Passing on info i found out the hard way.
The pull Rite super glide hitch moves backwards as you turn allowing for short bed trucks . However there is an adjustment screw that makes it hard to turn by hand. (the trailer has enough force to do it) . If this adjustment is allowed to go soft making it fairly easy to turn...RE-HITCHING the trailer could be difficult if not impossible . As you back up the hitch turns slightly instead of locking the clamp to the pin. By adjusting this screw (see photos) the hitch will stay straight during connecting and lock properly.
bigdo1
All Things Towing
May 12, 2018 05:43 AM
Blackbeltdually
Aug 21, 2016 05:29 PM
Bigdon68
All Things Towing
Jul 18, 2016 01:46 PM
Stevie Ray
Feb 22, 2007 01:23 AM
spongebobshane
All Things Towing
Jul 20, 2004 06:12 AM
