Anyone have an injector harness wiring diagram?
I need a wiring diagram for the injector harness, I just went through the harness to see if I had any broken wires, there was one, so I repaired it.
But...there is a wire that looks like it's cut off and it has a butt connector on it close to where they cut it off, I don't seem to see where it ever went, the wire is on bank 2 (driver's side injectors) and is red with a white stripe.
The motor is a 5.0 1996 coilpack motor
Attached are the fuel injector wiring diagrams. Unfortunately they are not specifically of the fuel injector harness per se. I don't find a red/white wire in the area. Is there a chance that maybe that splice connects to a different wire on the other end of the splice/connector, and maybe it was added at one time for the tachometer signal for a remote start system or something?
-Rod
-Rod
-Rod
-Rod
SpringerPop
11-20-2013 08:07 PM
