2006 F250 sensor issue
Old Sep 17, 2020 | 10:24 AM
airborne0130's Avatar
airborne0130
Good morning,
I have a 2006 f250 6.0 completely stock , I had a issue the other day where I was showing negative boost ( on torque pro app ) and my gauge was below zero also. I pulled the codes on it and it was P0107,P00069, p0405, p0470, p0472, p0672, p2286, p2287. I though maybe my map sensor was the issue so I purchased a new one and put it in also checked the connectors and wires and it seemed to fix the issue, boost was reading correctly and everything was good. Fast forward to last night truck began having the same issue with the check engine light and wrench light, though well the sensor went out again , I changed it again and i also went and inspected the ebp sensor ( cleaned it and the tube ) checked wiring. Drove it and seemed to fix it again, well I made it about 3 miles down the road and the wrench light popped up and I had no throttle response, shut the truck off restarted it and seemed to be working again, until about another couple miles and wrench light came back on. Can someone point me in the right direction?
Old Sep 17, 2020 | 10:41 AM
redford's Avatar
redford
FTE Leadership Emeritus
Thread moved to 6.0L PSD engine forum.
These guys will give you some good advice.
Old Sep 17, 2020 | 12:16 PM
xcrsp440's Avatar
xcrsp440
Where did you buy your sensor?
Old Sep 17, 2020 | 12:22 PM
bismic's Avatar
bismic
All the codes seem to indicate a bad EBP sensor. Go OEM with a new one.
Post the Baro sensor reading.
Also, the ICP connector or wiring is probably bad.
Old Sep 17, 2020 | 12:47 PM
airborne0130
The map and BARO reading with key on engine off was 14.3psi
Old Sep 17, 2020 | 12:59 PM
bismic's Avatar
bismic
Those are good. What was the EBP reading?
Old Sep 17, 2020 | 01:53 PM
airborne0130
EBP reading
6.3 key on engine off. Then 26.6 when its idling
Old Sep 17, 2020 | 01:56 PM
airborne0130
6.3 with key on engine off
Old Sep 17, 2020 | 02:09 PM
bismic's Avatar
bismic
Sounds like it is a bad sensor to me.
Old Sep 17, 2020 | 02:12 PM
FiveOJester's Avatar
FiveOJester
Originally Posted by airborne0130
EBP reading
Like Mark said a bad EBP sensor. Should be really close to MAP & Baro engine off, and 1-2 psi above baro when idling. Yours is WAY off!
I think you can unplug it for the time being, but would defer to others more knowledgable than me if the engine will go to a "default" tuning in that state.
Old Sep 17, 2020 | 06:08 PM
airborne0130
Update , purchased new bps and tube , ran good for about 5 miles then same thing. Readings while drive was 16.3psi but then when it acted up it went right back to 6.3 psi . Anything else to check
Old Sep 17, 2020 | 06:19 PM
bismic's Avatar
bismic
you buying OEM sensors? have you inspected the wiring to the sensor?
Old Sep 17, 2020 | 06:23 PM
airborne0130
Only thing that was replaced oem was the map sensor and I’m getting one of them tomorrow
airborne0130
Didn’t mean to but was meant wasn’t ....
Old Sep 17, 2020 | 11:12 PM
Syphlyn's Avatar
Syphlyn
what brand was the EBP sensor.
Youre horrible at answering questions
