Carb Help- identification
Old Sep 16, 2020 | 05:58 PM
mwhitely1's Avatar
mwhitely1
So I have reran all news fuel lines and got both tanks going. Now time to tackle the carb. It has no identification tag. 351 engine with mechanical fuel pump. I have a leak and fuel coming out of the weep hole under the accelerating pump assembly. Looks like I need to rebuild it since the truck has sat for 7 years. Any ideas on model? 2150?
Old Sep 16, 2020 | 06:27 PM
85e150's Avatar
85e150
Since you have a carb of unknown origin, take a look at the video here.
Click on "Can't find a carburetor number", or on the second link.
The difference in power valves, float settings, accel pumps can add up to a bog, flat spot or other irritation. A little extra time getting the right kit would be well worth the effort.
https://www.carburetor-parts.com/215...its_c_571.html
https://www.youtube.com/watch?v=TEuy...ature=youtu.be
Old Sep 16, 2020 | 10:37 PM
matthewq4b's Avatar
matthewq4b
[QUOTE=mwhitely1;19482998]So I have reran all news fuel lines and got both tanks going. Now time to tackle the carb. It has no identification tag. 351 engine with mechanical fuel pump. I have a leak and fuel coming out of the weep hole under the accelerating pump assembly. Looks like I need to rebuild it since the truck has sat for 7 years. Any ideas on model? 2150?
Yup a 2150 As for the CFM rating that this is obscured it will be on the fuel bowl on the driver side it is being obscured by the bracket being used for the trans kick down return spring in the third pic.
It should be something like 1.08 (287 CFM) or 1.21 (351CFM) being a 351 it should have the 1.21 venturi bore carb on it.
3twinridges
May 15, 2020 08:27 PM
damic
Feb 23, 2020 08:23 AM
adoublenickel
Sep 19, 2018 06:34 PM
CelticOne
25
Sep 14, 2015 03:56 AM
86 WV_F150
Dec 29, 2009 09:56 PM
