Sponsored by: Auxito
Breaking and Steering
Old Sep 15, 2020 | 10:29 PM
Rizzo1984's Avatar
Rizzo1984
I have 2003 f150 4wd with the 5.4. Today my truck started making noise from front end when I would be using the breaks and turning the wheel at the s and me time. Is there a specific cause or multiple causes?
Old Sep 15, 2020 | 11:06 PM
Lime1GT's Avatar
Lime1GT
Could be the brake pad wear indicator telling you the brake pads require changing. Could also b e a worn wheel bearing hub assembly.
Old Sep 16, 2020 | 04:27 AM
Rizzo1984's Avatar
Rizzo1984
Thank you I also noticed what sounded like a flat tire on driver side front but it's not. Maybe alil low on air but no where near flat. Can that be wheel bearing/hub. I forgot to put that in there.
Old Sep 16, 2020 | 11:54 AM
Lime1GT's Avatar
Lime1GT
Your going to have to check your brake linings. If you live in an area with salted roads the inner rotors have a tendency to rust while the outboard side looks fine. To check the wheel hub assembly you have to lift under the lower control arm until the tire is just off the ground. Then you grab hold of the tire trying to move the tire top to bottom. There should be no play. Spinning the wheel should be smooth with no grinding feel. If you don't know how to do this safely take it to a garage for an inspection.
Old Sep 16, 2020 | 12:49 PM
Rizzo1984's Avatar
Rizzo1984
Thank you I'll try that as soon as I get home
Gangley
Sep 26, 2013 08:42 AM
Tanner2255
Sep 30, 2012 06:41 AM
umj
1997 - 2003 F150
Feb 3, 2010 06:56 PM
triton54
1997 - 2003 F150
Aug 7, 2006 09:10 PM
99'FordExplorer
Jul 26, 2006 08:00 PM
