Another 4.30 thread
Old Sep 17, 2020 | 06:41 AM
  #31
George C's Avatar
George C
Your choice.
IMO, I get a 4:30 in an underpowered 6.2L. They need all of the help they can get. When an engine struggles to get in the 300-375 range of torque, there aren’t many choices except to increase gearing and making the best of it...
I know.. I also own a 2015 2500SD with a gasser/4:10 gears. Just pathetic..
There are also a select few who have never owned a 10 speed, but give advice on the 10 speed... The 10 speed is the game changer and allows options the 6 speed can’t..better control over RPM in any gear..
With the higher ratio, you can have the highway pulling power of the lower gears by locking out 10th. Same overall ratio of the low gear option is now available .. BUT, when not towing, the ability of efficiency is there with 10th. The 7.3L offers a good improvement in gas, and coupled with a 10 speed can offer the best of both worlds, so I would suggest not marooning yourself with guzzle gears.
In a diesel where induction is forced and three times the torque available, an even higher gear challenges the engine to produce more boost. I chose 3:31 gears on my order, and towing 10k is like towing nothing at all.
Old Sep 17, 2020 | 07:44 AM
  #32
BillyE's Avatar
BillyE
I’ve never wanted less gear.
Old Sep 17, 2020 | 08:08 AM
  #33
pennsylvaniabo's Avatar
pennsylvaniabo
if you are buying this to tow....go 4.30. Its a gas truck, made to rev, even with a new 10spd....
Old Sep 17, 2020 | 10:16 AM
  #34
kluger's Avatar
kluger
As a 6.7 owner, had 3.31 in my 2011 and towed 8 - 10k. Never felt like it had trouble getting moving. Yes, a taller gear would have more grunt off the line, but I didn't miss it. Had to be easy on the throttle or it would spin the tires. Got a 2020 F-350 ordered with the 6.7 and 3.31 again.
My last gasser was '96 Suburban with the 7.4 and 3.73 rear end IIRC. Now that could have used the 4.10 when towing.
chriscris
Jan 9, 2013 11:35 AM
X-Hibition
Jun 27, 2010 06:29 AM
shanksyamaha
Modular V10 (6.8l)
33
Aug 4, 2009 12:15 PM
hatemakings/n
Apr 22, 2008 07:15 AM
sa_rains
Jan 29, 2005 11:36 PM
