Another 4.30 thread
Old Sep 16, 2020 | 09:40 AM
acadianbob's Avatar
acadianbob
I love my 4.30's. I don't see a downside. Yes, the 10 speed can run in lower gears with 3.55's and make it work. But, if 3.55's run in 7th while the 4.30's run in 9th for a equivalent load, the 3.55 truck will effectively only have a 7 speed transmission while the 4.30 truck will have a 9 speed. Smaller gaps between gears with the 4.30 truck.
Old Sep 16, 2020 | 01:03 PM
David Harrington's Avatar
David Harrington
But Bob - you love your 4.30s with the 6 speed transmission. If you could have the 10 speed, would you stay with 4.30s? The 3.55 would give you everything you have today across 8 gears, plus a taller 9th and 10th.
I know it would help to test drive several trucks, but the dealer lots around here are bare.
Old Sep 16, 2020 | 02:05 PM
samuse's Avatar
samuse
Why buy a brand new truck with a bigger more powerful engine and then get higher gears so that you have no performance gain??
Old Sep 16, 2020 | 02:13 PM
jdk1's Avatar
jdk1
Are the 6.7 guys ordering 4.33 gears? I see a lot of 3.31 gears in those.
Old Sep 16, 2020 | 02:16 PM
twowheelyankee's Avatar
twowheelyankee
I hate the fact that my 2020 F250 is coming with 20's. I am old school and prefer more rubber than rim. But the times are a changin'. I'll add that on my 06 F150 I wish I upgraded the rear diff from 3.73. I tow an enclosed motorcycle trailer (under 5000 lbs), but I lift all my trucks. I put a 6" lift with 35's on this truck and it is a dog. So if you plan on going to 35's or 37's, the 4.3 will perform better [In my opinion].
If no plans to lift, then listen to the experts above. If you plan to lift and tow heavy...... well..... my answer is null and void
Old Sep 16, 2020 | 02:19 PM
Thevol's Avatar
Thevol
Actually the 6 speed w/4.30 has a lower 1st gear ratio than the 10 speed w/ 3.55. This is very noticeable when taking off from a stop with a heavy load, where the most strain is on the drivetrain.
Old Sep 16, 2020 | 02:50 PM
7.3Tremor's Avatar
7.3Tremor
I will say the 4.30 with the 10 speed is fantastic. I'm in a Tremor so I have the 18" wheels with 35" of tire and there is no need for anything more power wise. Merging onto the highway is far easier than my '13 F150 with 3.55. Cruising at 70mph my tach reads right at 1500rpm if I remember correctly, been awhile since I was at that speed. As far as towing, I had a 3 horse bumper pull empty weight of 4k loaded down with 3 horses, all their tack, full bed, 4 adults.. (so a fair load somewhere in the 9k range) was going up SC hills at 70 in 7th and gaining speed, only lost about 1-2 mpg from what I typically run around town.
Old Sep 16, 2020 | 03:20 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Well, the 6.7L only has the options of 3.31 and 3.55 unless you go dually. And like the gas trucks, all the dealers just default to ordering the taller gear ratio.
I think 4.10's would be perfect for the 6.7L/10spd combo.
Old Sep 16, 2020 | 04:15 PM
Iconic7_3's Avatar
Iconic7_3
Unfortunately I didn’t know a lot about gearing until 6 weeks after I ordered my 7.3L and already had a VIN so it is what it is, dealer pushed me to 3.55. Ive been towing 7-8k depending on cargo with a 2013 expedition with 3.73 and tired of the trailer driving the tow vehicle so already knew I wanted a 3/4 ton. Never owned one and I had to order because nothing was on the lot for months. I tow under 10k so don’t expect an issue as many have reported good performance at those weights but if I decide to go bigger on a trailer or get annoyed with the “gear hunting” a gear swap would be cheaper than trading the truck in so my question is with the new 10 speed do you have to do any transmission reprogramming when swapping gears?
Old Sep 16, 2020 | 04:38 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
The more gears, the more it is going to gear hunt. The 10spd is going to 'hunt' a lot more than your previous vehicles. Whether that's a bad thing or not is up to you...
Old Sep 16, 2020 | 04:48 PM
jdk1's Avatar
jdk1
These are not heavy trailers we’re talking about, so there should be any issue at all. What Ford is doing is putting higher gear in bigger engines. That’s why the default 7.3 gear is 3.55 (except in the Tremor with big tires) and the 6.7 appears to be 3.31. And yes, I understand it’s for fuel economy.
One more issue I keep seeing is the concern over 3.55 gears in the 7.3 putting strain on the drive train. Unless I’m mistaken, it’s the same drive train as the 6.7. So a 6.7 cranking out 1050 ft lbs of torque with a 3.31 gear would be A LOT more strain than anything the 7.3/3.55 could do. Someone please correct me if I’m wrong on this aspect (as if I have to ask).
Old Sep 16, 2020 | 04:52 PM
jdk1's Avatar
jdk1
I agree. I bought a 7.3/3.55 because that’s what was on the lot and everything else was perfect on it. A 3.73, or maybe even a 4.10, would’ve been more ideal. Though I’m not worried about the 3.55 performance, it’s just nice to have more options.
Old Sep 16, 2020 | 05:53 PM
  #28
Thevol's Avatar
Thevol
The gas 10 speed is not as beefy as the diesel but very similar, think there is some additional clutch material in the diesel and some other beefed up components cannot remember for sure, TC prob diff as well. But yeah I dont think it will make much difference in component life as it should handle the strain of either gear ratio, its just the 4.30 gives you more mechanical advantage to get the load rolling and mostly likely more usable gears while towing (unless you can often pull 9th or 10th with your load and 3.55).
Old Sep 16, 2020 | 06:01 PM
  #29
Reactor111's Avatar
Reactor111
I like the 4.30 with the 7.3 because it only has 470 lb/ft of torque. All 10 gears of the trans are available in normal driving. With the 3.55 you will be lucky to see the higher overdrive gears in normal driving. Now if you have a 6.7 with 1000lb/ft of torque, you could pull the higher gears easily. In my humble opinion, the 10 speed trans and the 4.30 gear are the perfect combination with the 7.3.
Old Sep 16, 2020 | 08:51 PM
  #30
Mike Ski's Avatar
Mike Ski
I've pulled my 5th wheel about 3500 miles with the 7.3 10 speed 4.30 combo. I don't lock out any of the gears and the truck will chug along in 10th on the flat highway doing about 65 mph with no problem. With the 4.30s, form a stop the truck gets going very easily while pulling trailer. The 7.3 has quite a bit more torque on the low end compared to my old 6.2 w/ 4.30s and in general I'm always turning a lower RPM because of it. With 4.30s I can use all 10 gears. Overall I'm very pleased with the performance. Good luck with your new truck.
