Done for 2 more years
Old Sep 10, 2020 | 05:04 PM
Motohead911's Avatar
Motohead911
Yippie, just passed my CA smog again, good for two more years.
Old Sep 11, 2020 | 05:45 PM
JJ1101's Avatar
JJ1101
Do you know if they plug into the ODBII and check for codes? I need to get my truck smogged as soon as I get it running.
Old Sep 11, 2020 | 05:51 PM
Motohead911
They did a visual check, plugged into the computer for an OBDII check and a snap test.
Old Sep 11, 2020 | 05:55 PM
JJ1101's Avatar
JJ1101
Ok, that doesn't sound too bad. I'll make sure there are no codes before I take it in.
Old Sep 11, 2020 | 06:06 PM
Motohead911
I don't know if you have Torque Pro, but it does have a nice feature in that it lets you check your emissions readiness monitors. If you have to clear any codes it will tell your when they a ready.
Old Sep 11, 2020 | 06:23 PM
JJ1101's Avatar
JJ1101
I had it on my old phone. I will buy it for my new phone and try that. Thanks for the info.
Old Sep 12, 2020 | 06:32 AM
Yahiko's Avatar
Yahiko
Also make sure that the readiness monitor is set or you won't pass.
This is from NY but it still is useful info.
https://dmv.ny.gov/brochure/what-do-...cars-not-ready
Readiness monitors
Featured snippet from the web
These tests are commonly referred to as "readiness monitors." The readiness monitors
identify whether the vehicle's computer has completed the required "tests" while the vehicle
is being driven. ... The test equipment reads the OBDII and readiness monitor status as
part of the vehicle's emissions inspection
Old Sep 12, 2020 | 12:27 PM
diesel_dan's Avatar
diesel_dan
And the type of test depends on your county in CA - ours is only visual and OBDII plugged into their computer. Ours just passed a couple weeks ago too... BTW: I asked my smog guy about PCV catch cans in general and he said as long as he can follow the lines to the can and back to where it normally goes into intake stream, and can tell it is a closed loop, they're just fine...
Old Sep 14, 2020 | 01:50 PM
FiveOJester's Avatar
FiveOJester
Same procedure here in Fresno county. Never had any problems passing my (2) 6.0's but they were both 100% stock.
Old Sep 14, 2020 | 01:56 PM
JJ1101's Avatar
JJ1101
I'm in Kern County and I haven't done a smog in a couple of years. I didn't know if anything changed.
GeneGregory
Nov 19, 2016 02:51 PM
F250army45d
41
Sep 20, 2011 09:51 PM
"Beemer Nut"
21
Jan 25, 2009 11:13 AM
Texas80F150I6
Nov 10, 2004 05:03 PM
fatdaddy
Aug 20, 2002 12:52 PM
