Body alignment
Old Sep 10, 2020 | 05:54 AM
150R's Avatar
150R
Body alignment
Hey fellas, I bought a 78 custom and was wondering about cowl and fender alignment, it seems the cowl hangs over the fenders on the ends yet doors are lightened up well is that normal? Thanks Robert in Tn.
Old Sep 10, 2020 | 06:37 AM
Meridian_Mike's Avatar
Meridian_Mike
It's kinda hard to imagine what you are saying without a pic or 2...... BUT....
I'm pretty sure you can adjust that out. It sounds like the front fenders are not lined up with the cab correctly.
Old Sep 10, 2020 | 06:44 AM
150R's Avatar
150R
Thanks for the reply i will try to get a photo up soon
Old Sep 10, 2020 | 12:58 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Ever seen a cat chase its tail, same as chasing matching cowl, fender, hood and door gaps. Toss in a cab to bed "dent" line...Remember cowl is set and fixed. So it all is a tail chase to get them where you can live with them. Fenders can push out a bit (for cowl drop to fender edge alignment), but then the doors have to follow the fender, front edge of door. But at least the rear edge has to match the cab. And then toss the "dent" line into the mix. IMO the cowl to fender L&R gap (which I think should be set 1st anyway) and can only can be adjusted by raising or lowering the front of the fender/via the radiator support. Round and round she goes.
Old Sep 10, 2020 | 03:24 PM
dwirth's Avatar
dwirth
I just put my front clip together and my cowl hangs over my fenders. Door and fender match up perfectly
Old Sep 10, 2020 | 04:34 PM
meangreen92's Avatar
meangreen92
I'd think you could loosen the bolts in the door jambs and the bolts at the rocker panels, and be able to pull the fenders out to where they line up with the cowl. You might also have to loosen some of the bolts along the top of the fender, but it should work.
Old Sep 10, 2020 | 11:32 PM
440 sixpack's Avatar
440 sixpack
The cowl and the hood both hang over the fenders . try to minimize it but you can't eliminate it.
FuzzFace2
20
Jan 21, 2017 07:32 PM
kev03
Jan 18, 2015 12:51 AM
tt3898
15
Aug 5, 2011 02:07 AM
joe black
25
Nov 4, 2006 01:15 AM
turbosek2
Paint & Bodywork
Mar 12, 2003 12:16 AM
