Tire Load Rating
Old Sep 9, 2020 | 02:42 PM
Lmhayes88's Avatar
Lmhayes88
Tire Load Rating
I am looking into putting 37's on my 2020 and have been comparing different sizes. I was looking at the nitto ridge grapplers and the D load rated version has a higher maximum load rating then the E load rated. Should I stick with the E load rated since that is what is on it or go with the D load rated since they can handle a higher maximum load?
Old Sep 9, 2020 | 03:16 PM
ford390gashog's Avatar
ford390gashog
A D rated tire holds less than a E rated tire.
Old Sep 9, 2020 | 03:21 PM
morleyz's Avatar
morleyz
It depends on your use I suppose. The E has 10 plys, D has 8. E is generally going to be stiffer than a D and will usually have a higher maximum pressure require to achieve maximum load, so more stability when towing, probably a harsher ride when empty. That being said, as long as they're both capable of meeting the load requirements for your truck, I'm guessing those tires would have very similar seat of the pants characteristics.
Old Sep 9, 2020 | 04:15 PM
Papa-103's Avatar
Papa-103
A tire with a lower ply rating I think would have a softer side wall. Even though the tire has a higher weight rating it is because it is a bigger tire not a stiffer side wall. I would be concerned about getting flex in the side wall, causing a slight sway motion with a max load on the truck. I would talk to a "truck" tire dealer to verify my theory if you tow or haul heavy loads.
rsylvstr
May 22, 2009 10:52 PM
jefftb
All Things Towing
Jul 6, 2008 11:36 AM
diver45
Dec 5, 2007 04:45 PM
bullit340
Nov 26, 2006 01:19 AM
wipper
Aug 11, 2004 04:14 PM
