2014 maintenance
Old Sep 5, 2020 | 05:24 PM
clike's Avatar
clike
2014 maintenance
New to the forum here. i was wondering what you all recomend for the 100000 mile maintenance?
2014 f 150
4 wheel drive
302 motor
96000 miles
i have always had ford change and rotate tires every 5000 miles
No other maintenance has been done
thanks
Old Sep 5, 2020 | 10:04 PM
steve(ill)'s Avatar
steve(ill)
sparkplugs change--- and rubber boots
have you had the transmission drained and new oil added ?
axle lube / transfer case / oil changes
Old Sep 6, 2020 | 09:09 AM
clike's Avatar
clike
I havnt done anything but oil changes
Old Sep 6, 2020 | 08:27 PM
gDMJoe's Avatar
gDMJoe
clike - New to the forum here. i was wondering what you all recomend for the 100000 mile maintenance?
2014 f 150
4 wheel drive
302 motor
96000 miles
Have you referenced the Scheduled Maintenance section of the owner's manual? *For starters at least. There's also should be some considerations for conditions (e.g. dusty) and use (e.g. towing, off-road).
(owner's manual) Don't have one -OR- would like a digital, searchable desktop document?
Owner's Manuals ««« -click-
» Select Your Year [ Choose One ]
» Select Your Make [ Choose One ]
» Select Your Model [ Choose One ]
Also as an FYI - The term "302" typically refers to the pushrod Windsor V8. The last year for that "302" in an F-series Ford was 1996. The current 5.0L isn't actually 302 CI engine.
DSLPWRD
6.7L Power Stroke Diesel
Mar 23, 2012 09:58 PM
Katmandu
Modular V8 (4.6L, 5.4L)
Nov 4, 2010 02:45 AM
dzldude
May 15, 2008 08:33 PM
popsbronco
1966 - 1977 Early Broncos
Apr 24, 2004 12:56 PM
