Transfer case differences
Old Sep 5, 2020 | 07:10 AM
MIF-150's Avatar
MIF-150
I have a '19 XLT 4x4. What is the difference between this transfer case and the transfer case in the Lariat trim level and above? I know mine is a shift on the fly and the more expensive models have the '4A' setting, and I know the operational difference. But is the mechanical difference more that just the switch? can a '4M' be converted to a '4A'?
Inquiring minds want to know!
Thanks
Timm
Old Sep 5, 2020 | 09:59 AM
deserteagle69's Avatar
deserteagle69
Thanks
Timm
Yes, and no! The transfer cases are different mechanically and cannot be converted. You'd have to do a swap to get a transfer case with the 4A setting.
Old Sep 5, 2020 | 11:54 AM
Stealth13777's Avatar
Stealth13777
The transfer case with 4A has what is essentially a clutch in it that allows for different wheel speeds without breaking stuff. Clutch may not be the right term, but at least conveys the idea. So yes, they are mechanically different.
There may also be electronic differences depending on how they chose to control the torque split.
Old Sep 6, 2020 | 10:55 PM
RedRage's Avatar
RedRage
I think it has an electrically actuated clutch. Is that right? I'm not sure.
Old Sep 6, 2020 | 11:03 PM
ford390gashog's Avatar
ford390gashog
The transfercase is a BW TOD unit. Yes you can convert your truck to AWD all you need is the switch, transfercase and programming.
cryptonik420
Dec 3, 2002 12:57 PM
coloranger
Jul 21, 2002 11:12 PM
sparky
Jan 14, 2000 07:07 PM
