Electrical Question
Old Sep 5, 2020 | 03:15 AM
Stangman70's Avatar
Stangman70
Electrical Question
Weird electrical issue tonight.
Truck was sitting in the parking lot at work and had been sitting there for several hours. I watch cameras as part of my job and so I typically park the truck in the lot where there is a clear view from multiple sides. I happen to glance over and notice that the running lights are on. I didn't have the lights on at all before I parked it for the evening. I reviewed some footage and the lights popped on by themselves a few minutes before I noticed. Not the headlights just the running. I went out and checked the switch and it was most definitely pushed all the way in. That switch is also brand new.
Truck has never done this to my knowledge before. Any ideas of why this happened? Fuses (which are also new)? Grounds?
Thanks!
Old Sep 5, 2020 | 03:40 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Maybe Henry Ford wanted to check out something? Maybe internal failure of the headlight switch?
Old Sep 5, 2020 | 03:43 AM
Stangman70's Avatar
Stangman70
It was a full moon here the other day and I hope he liked what he saw.
Old Sep 5, 2020 | 09:07 AM
dlburch's Avatar
dlburch
when you say running lights, were the side markers also on? And are they still on, or did you do something to make them go off??
Old Sep 5, 2020 | 09:34 AM
Stangman70's Avatar
Stangman70
Yes side markers and I turned the lights "on" and then off again.
Old Sep 5, 2020 | 04:08 PM
1TonBasecamp's Avatar
1TonBasecamp
Probably a bad "new" switch. First time I've heard of your particular problem, but having bad electrical components right out of the box is rampant. Having them fail a week or two into their service is even more common than having them bad right out of the box.
A fuse being bad can't cause electricity to flow no matter how it's bad. The power is coming from somewhere before it gets to the fuse. So wherever that source is, or the wiring in-between, is your problem.
I suspect the new switch. But what was the reason for changing it out in the first place? Other problems cropping up?
Paul
Old Sep 5, 2020 | 04:16 PM
Stangman70's Avatar
Stangman70
Paul
I had been chasing a dash light problem and decided to replace all the common causes. So new switch, fuses, LED bulbs, etc. With the hours I work(graveyard 12 hour shifts) I havent needed the lights at all before until the recent change in weather.
Old Sep 5, 2020 | 09:12 PM
meangreen92's Avatar
meangreen92
Try jiggling the switch while it's in the Off position, and see if you can get it to duplicate the fault. A dark garage will work, as will a mirror in front of the truck showing you the lights, but if you could wire in a buzzer that might be better for detecting a short few milliseconds of current flow.
Did you notice if the gauge lights were on too? I think they'd almost have to have been on.
If it's a phantom positive voltage problem, then the current could be coming from either side of the fuse - but it could be coming from outside the light switch. Or am I reading that wrong?
I think it's the switch too.
Old Sep 5, 2020 | 11:40 PM
1TonBasecamp
Yes, from the switch, or from outside the switch. Just not the fuses themselves was what I was saying. As they're just in the middle of the circuit, nothing is coming from them. So replacing them would not change anything.
In theory at least...
Paul
Old Sep 5, 2020 | 11:45 PM
1TonBasecamp
And Stangman, if you have other lights work but the dash lights still don't, you might try reversing the bulbs. Some LED's (all of them?) are polarity sensitive and will only work when inserted one way. Be nice if the manufacturers would make this plain and clear to purchasers.
And I should talk, as many of our products seem so intuitive that we neglect to even include instructions! Well not everyone has worked on these trucks for 40 years as it turns out, so yeah, instructions would be nice sometimes!
And by your username it sounds like you've been around old vehicles for awhile now at least? So you know that the dash lights are all controlled through the rheostat section of the light switch so you have to turn the **** to make them brighter?
Figured I'd add that just in case, since it's come up literally three times on different forums just in the last month or so. Worth checking at least.
Paul
ptexrican
Feb 26, 2019 06:32 PM
ottawaguy
Escape & Escape Hybrid
Feb 18, 2011 07:52 PM
Old Medic
15
Dec 3, 2010 12:59 PM
ebaugh90
May 8, 2009 12:45 PM
jetjock16
Aug 20, 2003 10:48 AM
