Minnesota Chapter Join Chapter, Leader: fordpower88
Fall is coming BS thread.
Old Sep 29, 2020 | 04:55 PM
  #151
fordpower88's Avatar
fordpower88
Its about that time. Boss says its time to go home for the day.
Old Sep 29, 2020 | 08:44 PM
  #152
DieselCamper01's Avatar
DieselCamper01
Good evening guys. Got the topper back on the truck tonight. All by myself. That was interesting.
Old Sep 29, 2020 | 09:21 PM
  #153
fordpower88
Evening Jay! I bet that was interesting.
Old Sep 30, 2020 | 06:18 AM
  #154
DieselCamper01
Good morning and happy hump day.
Old Sep 30, 2020 | 07:12 AM
  #155
fordpower88
Good morning Jay! Oh yeah we made it to Hump Day!
Old Sep 30, 2020 | 07:54 AM
  #156
wildstang's Avatar
wildstang
VT Chapter Ldr
good morning MN. A little cooler your way? We finally got some rain last night and still some this morning. Really took the leaves off the ash trees around here.
Old Sep 30, 2020 | 07:57 AM
  #157
wildstang's Avatar
wildstang
VT Chapter Ldr
Originally Posted by MisterCMK
Nice job Jim.
If you had a yamaha it wouldn't need a new seat cover 😉
Originally Posted by DieselCamper01
Happy Sunday guys.
We had a good day Troy except for Chris. Something is failing in the rear differential. So Lynn rode wiry her sister and Chris rode and drove in ours. So still had fun.
At least he has a nice seat cover on the yamaha bummer something is wrong with it. the front left wheel on mine is making a pretty good snapping noise. I can see the tire kind of shake when it catches and releases. Not sure if maybe a wheel bearing? Investigation is needed.
Old Sep 30, 2020 | 12:01 PM
  #158
DieselCamper01
Can barely see the grass in my yard for all the leaves.
Yours is maybe a wheel bearing but more likely the axle joint is going bad.
Old Sep 30, 2020 | 12:05 PM
  #159
DieselCamper01
Chris and I bent up some conduit to make a framework on the utility trailer. I will then strap a tarp over that.
Old Sep 30, 2020 | 01:38 PM
  #160
wildstang's Avatar
wildstang
VT Chapter Ldr
it has cv joints on it. I jacked it up and had a bunch of in out with the tire when rocking it holding it at the 6 and 12 oclock positions. I pulled the knuckle off it and the axle nut was only finger tight with the cotter pin in. The boots look good on it and felt free when moving the joints around. I torqued the nut to what it should be, still have a little play but much less but that looks like a little ball joint movement now. The wheel bearings felt good. I'll try it again sometime. Could be the cv joint. that is what I was thinking at first but not sure how to check one to know if it is good or not.
  #161
fordpower88
Looks good Jay! That going to be your new man cave if Lynn gets mad and kicks you out of the house?
Old Sep 30, 2020 | 01:58 PM
  #162
DieselCamper01
I think I may opt for the camper instead.
Old Sep 30, 2020 | 08:09 PM
  #163
DieselCamper01
Got the hitch put on the Taurus after work. Tomorrow night will be front brakes and rotors.
Old Sep 30, 2020 | 08:56 PM
  #164
fordpower88
What's the plan for the taurus that you need a hitch?
67 Olfthfl
Nevada Chapter
Jun 17, 2020 07:59 AM
fordpower88
Minnesota Chapter
192
Oct 31, 2019 03:02 PM
fordpower88
Minnesota Chapter
181
Sep 30, 2019 08:44 PM
Sparky83
Vermont Chapter
1336
Oct 31, 2017 11:37 PM
fire240
Idaho Chapter
405
Aug 1, 2011 08:45 AM
