Need help video attached
Old Aug 29, 2020 | 08:45 PM
Tinkermel's Avatar
Tinkermel
Need to rack other brains. We were on the freeway, when truck lost power and just sputtered out. No smoke etc. Just kaput. Able to get it towed home, and we just cannot figure out wth is going on. It acts fuel starved. We have replaced: CPS, ipr, icp, icp pigtail, fuel filter, oil change, in line pump, hutch/harpoon, fuel pump relays, EOT, EOP, and ebp sensor. Please let me know after hearing if you have ideas.
https://youtu.be/iVlk33offwI
Old Aug 29, 2020 | 09:13 PM
Brian Hanks's Avatar
Brian Hanks
Have you checked fuel pressure? Do you have a gauge?
Do you have a way to read codes and monitor systems? FORScan, etc?
Old Aug 29, 2020 | 09:21 PM
Tinkermel's Avatar
Tinkermel
Just got one today.. going to check it tomorrow. Been leaning towards HPOP, but it doesn't have the black smoke etc . Idk
Old Aug 29, 2020 | 09:52 PM
Brian Hanks
Really need to get a means of monitoring the system with FORScan with a computer or phone to see what the HPOP etc are doing before you start throwing more money at parts. A Bluetooth adapter or Usb connector for computer can be had very cheap and save you lots of time and money.
Old Aug 30, 2020 | 02:03 AM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
Listening to the video I hear a noisy injector then a gradual dying. Kinda want to agree with you, sounds like fuel starvation.
Is the fuel tank below 1/4? If yes get it up to 1/2 and see if it runs ok. If yes, then that points to a broken fuel pickup foot in the tank. Fairly common. Google Hutch and Harpoon mods.
If no change the fuel pickup screens in the tank may be clogged. A simple way to check is to remove the hose from the rear of the fuel pump and blow shop air back to the tank. Open the fuel filler cap first. The air will clear the screens temporarily. And yeah, fix is Hutch and Harpoon again.
Old Aug 30, 2020 | 09:59 AM
Brian Hanks
His initial post says he already did the Hutch/harpoon mod.
Old Aug 30, 2020 | 10:41 AM
Listor's Avatar
Listor
I saw that too , is it possible his mod (Hutch/Harpoon) came apart? checking for fuel pressure will help him with that
Old Aug 30, 2020 | 12:16 PM
timmyboy76's Avatar
timmyboy76
GIVE IT SOME THROTTLE
since you've done the HH mod, disconnect it from the pump and rig up a Jerry can...will eliminate possible bad pickup
Old Aug 30, 2020 | 03:09 PM
RacinJasonWV's Avatar
RacinJasonWV
I’d start with a fuel pressure check. Here’s a simple method. https://www.ford-trucks.com/forums/a...4&d=1592859516
Got plenty of oil in it?
Old Aug 30, 2020 | 03:30 PM
Walleye Hunter's Avatar
Walleye Hunter
Whew, that's a nice piece of change you've thrown at it. I hope you used all OEM sensors, as aftermarket sensors don't seem to work well. I second checking the oil level and I'd check fuel flow via the bowl's drain valve and catching the fuel out the drain tube that runs down the front of the engine on the passenger's side.
tarheel007
27
Nov 25, 2013 05:50 PM
SDElwood
Michigan Chapter
May 26, 2011 09:27 AM
Naked_Farmer
Mar 18, 2008 06:58 PM
roger 922
Mar 9, 2008 06:10 PM
Budkole
Apr 19, 2007 01:36 PM
