on a 79 f150 with a/c . the blend door in the cab passenger side did not work . pulled the cover off and found the pivot bracket was rusted and gone. are there any parts available
to repair these. all the foam and seals were shot as well. it was fairly easy to get out since the dash is not reinstalled yet. but i would like to restore what i can.
cant find vey much info on this.
You may also check with https://www.detroitmuscletechnologies.com/
If they don't list something for your car/ truck call them and see what they may have.
They did not have anything for the 80-86 trucks and with a little time they made seals for them.
I have used their AMC kit to rebuild the box on my 70 AMC Javelin, great kit.
Oh the hinge, look in the 80-86 area (blend door fix) for what they do to fix the same thing.
They use a piano hinge to fix the plastic one that breaks over time.
Dave ----
