Sync issue
Old Sep 10, 2020 | 06:42 PM
GABAR's Avatar
GABAR
Originally Posted by cpobst
I did a reset through Forscan. If I power it off then back on it works fine. It's random, just annoying.
Resetting or rebooting the APIM will not solve the issue because it’ll soon return.
Old Sep 10, 2020 | 06:47 PM
cpobst's Avatar
cpobst
I get it after they explained to me it will trigger a code while it's happening. What's frustrating is I went there twice while it was happening, the service advisor took pictures and scheduled an appointment for me to come back. I spoke with someone higher up the food chain, someone I've known for years and the next time it occurs he said bring it by and they will hook up to it right then.
Old Sep 11, 2020 | 12:58 PM
GABAR's Avatar
GABAR
I hope the APIM doesn’t have to be replaced but there’s a strong possibility you’ll need a new one.
If they have to replace the APIM, I hope you have a Ford ESP otherwise, it’s going to cost $500.00 plus to replace it with a new one.
Old Sep 11, 2020 | 01:03 PM
cpobst's Avatar
cpobst
I have the premium with $50 deductible which I already paid. They won't charge me that again they said.
Old Sep 11, 2020 | 01:48 PM
GABAR's Avatar
GABAR
Awesome.
I had to have my APIM replaced on my 2016 F150 awhile back and like you, I have a Ford Premium ESP $0 deductible so it didn’t cost me anything.
What‘s really want weird is that before it was replaced and while I was waiting on it to come in because they had to order it, whenever I would use Apple CarPlay, everything worked fine and flawlessly but whenever I would revert back and try to use the actual OEM SYNC interface, that’s when all of the problems would start happening.
Good luck on getting it fixed and working properly.
Old Sep 11, 2020 | 01:50 PM
cpobst's Avatar
cpobst
Thanks, I'll update when I have new info. I figure since I raised a little hell it won't happen again anytime soon. That seems to be how things work.
Old Sep 19, 2020 | 01:51 PM
2020KR350's Avatar
2020KR350
I started having issues with mine, sometimes it won’t come off the clock screen and other times it locks up and the home button starts blinking and it beeps every time it blinks. Is there a way to get it to stop while driving? I have been stopping and turning the truck off and restarting it to get it to reset.
Old Sep 19, 2020 | 02:55 PM
GABAR's Avatar
GABAR
Do you have the 8 inch screen?
Old Sep 19, 2020 | 03:29 PM
2020KR350's Avatar
2020KR350
[QUOTE=GABAR;19487063]Do you have the 8 inch screen?[/
Yes it is the 8 inch screen.
Old Sep 21, 2020 | 12:58 PM
GABAR's Avatar
GABAR
[QUOTE=2020KR350;19487096]
Okay.
Well, there’s no need to stop and turn your vehicle off like you have been doing.
All you need to do is hold down the power and track forward button until the screen goes blank and then release said buttons.
By doing this you’re doing a soft reboot of the SYNC 3 system.
With the weird problems you’re having, I would just do a Master Reset.
To do a complete Master Reset of the SYNC 3 which is a more extreme version of the above info, just hit the Settings button, then General, then scroll down to the bottom and hit Master Reset.
By doing the Master Reset, most if not all info that you’ve setup on the SYNC screen will be erased so you’ll have to set it up again. Below are things that will have to be setup again.
WiFi, Bluetooth, Radio and SiriusXM presets if you have SiriusXM.
I hope this info helps you out.
Have a good evening.
Old Oct 18, 2020 | 09:54 PM
cpobst's Avatar
cpobst
I just wanted to post a follow up. They updated all 3 modules with the latest and greatest and it's been fine ever since. I am thinking the issue is resolved now. It's been over 3 weeks since they did it and it hasn't happened once.
Old Oct 19, 2020 | 01:50 PM
GABAR's Avatar
GABAR
Very cool.
Did they replace the APIM or just updated everything with new software.
I hope this completely fixes the issues you were having.
Hapspkp
13
May 22, 2020 06:38 PM
hilfikerkg
2015 - 2020 F150
Nov 12, 2019 07:35 PM
bjmayberry2
16
Jun 1, 2019 05:58 PM
cruisetopdown
20
Feb 19, 2014 07:03 PM
jniolon
21
Aug 20, 2010 03:54 PM
