FE Build Ignition
Old Aug 27, 2020 | 08:07 AM
Lebros86's Avatar
Lebros86
6th Gear
FE Build Ignition
I can read and watch as many videos as are available, but I would prefer the opinions of real people base on past experience. Just starting build, looking for suggestions on ignition system. Ready to run distributor vs distributor and ignition box combination. Mechanical vs Vacuum. Build is going into a 75 F-250. Have no intentions of using for regular truck purposes as I have a newer truck for that. This is simply a toy and my form of stress relief. I appreciate the help.
Old Aug 27, 2020 | 08:22 AM
Tedster9's Avatar
Tedster9
Unless the plan is a track only motor, for drag racing, there is no benefit to deleting vacuum advance. An engine that only and ever runs at full throttle has no use for vacuum advance, simply because it would never be employed. But, if you're going to drive on the street, then you want vacuum advance. It does not hurt performance.
Old Aug 27, 2020 | 08:58 AM
440 sixpack's Avatar
440 sixpack
Even drag racers run vacuum advance unless they have vacuum so low they can't. all street vehicles need it.
Most aftermarket ignition systems are junk. the Duraspark II has it's problems as well but it looks correct and it works as well as the imported garbage you can buy.
Adammc224
23
Oct 3, 2019 10:26 AM
davisrats
Jul 3, 2009 09:33 PM
LARIAT 85
Nov 16, 2006 06:30 AM
cjbronco
Oct 13, 2005 09:40 AM
1950ford
Sep 6, 2005 11:24 AM
