Abs module mounting location
Old Aug 26, 2020 | 03:30 PM
2manytickets's Avatar
2manytickets
still doing final assembly in my truck. I need to see a clear photo of the abs module mounted so I can see why mine isn't sitting right.
Old Aug 27, 2020 | 01:05 AM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
No photo but it will be mounted in front of the driver side battery, to the body/fender a couple inches before the radiator support. See how the bolt holes match up.
Old Aug 27, 2020 | 09:59 AM
BWST's Avatar
BWST
Got Data?
Not sure this pic from my truck helps. Located where David mentioned:
Old Aug 27, 2020 | 11:39 AM
FordTruckNoob's Avatar
FordTruckNoob
These sections from the manual might be helpful.
Old Feb 7, 2021 | 03:12 AM
dante27's Avatar
dante27
Found the leak, it was in the front line from the master down under the batter support. Not that bad to replace now to power bleed the system and I'm all set - I hope. Thank you all for the help. I now know where my ABS Mod is located and hopefully never have to get at it again. The toughest part of the whole job was wrestling the air filter out then back in. I wish Ford had a better idea with that!
Old Feb 7, 2021 | 06:29 AM
FordTruckNoob
Well done. Thanks for coming back and closing out this thread too! Reps sent.
2manytickets
Aug 26, 2020 07:57 PM
The3ngineer
Mar 13, 2020 10:05 PM
ckb2steelers
Modular V10 (6.8l)
Aug 31, 2006 04:53 PM
