ABS module location
Old Mar 12, 2020 | 11:01 PM
The3ngineer's Avatar
The3ngineer
ABS module location
Can someone tell me where the ABS module is on a 2005 EX 6.0. Is it a big deal to swap out? TIA
Old Mar 13, 2020 | 08:46 PM
Dan V's Avatar
Dan V
Should be under the driver side battery.
Old Mar 13, 2020 | 10:05 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
To swap it out, you will need a computer that can access the "bleed" function so you can get all the air out of it after the swap. Otherwise, it is difficult to get the air out without driving it and manually bleeding A LOT.
Sous
Nov 27, 2019 09:07 PM
Wbrann51
Dec 15, 2018 06:18 PM
ckb2steelers
Modular V10 (6.8l)
Aug 31, 2006 04:53 PM
