1982 f100
Old Aug 25, 2020 | 08:57 PM
albynospyder's Avatar
albynospyder
1982 f100
so, let me rehash some info because I've been picking some brains in another thread about the truck I got and the rear end and tranny. So, to make a long story short, its 2wd, originally had a v6 automatic, now it has a 351w and a np435 transmission. I have a chance to get a 1973 mercury marquis brougham with a 429. Would it be worth the purchase? And would it fit? I know if it did it wouldn't be a direct swap, I'm just curious if it would be worth my time? Thanks guys.
Old Aug 26, 2020 | 07:41 PM
Franklin2's Avatar
Franklin2
No replacement for displacement. This company sell motor mounts and other parts to let it drop in place. https://www.landlproducts.com/
Old Aug 26, 2020 | 08:03 PM
85e150's Avatar
85e150
Not sure what shape your 351W is in. Seems like it's had some work.
https://www.ford-trucks.com/forums/1...l#post19451251
As far as a '73 Mercury 429, as OEM it was clanging around near the bottom of the barrel performance wise for a car 429. Compression had be dropped, power was down, smog controls were up. Without different heads, and a little other work, if your 351w is running right, it would probably run away from the 429, or do no worse than staying with it.
Old Aug 27, 2020 | 01:09 AM
FuzzFace2's Avatar
FuzzFace2
Your transmission will not bolt to the 429 so if you were to use the 429 you would also need the transmission that's bolted to it also.
Dave ----
Old Aug 27, 2020 | 02:08 PM
85e150's Avatar
85e150
The transmission will work, but the OP needs a bell from a 460* to bolt it up. He will also need the correct flywheel and clutch and maybe starter.
*'73 to '79 used mechanical clutch linkage, so that would be the place to look. These trucks also had T19s in them. 1st gear isn't a granny in those, so OP would have more of the "4 speed" feel, and still have a truck transmission if he wanted.
Old Aug 27, 2020 | 08:00 PM
FuzzFace2's Avatar
FuzzFace2
You are right don't know what I was thinking?
Think I was thinking auto?
The 80's trucks also came with T18's as that is what my 81 F100 had till I replaced it with a NP435 and the Advance Adaptors over drive.
Dave ----
Old Aug 27, 2020 | 08:06 PM
85e150's Avatar
85e150
ZF or M5OD are integral bell transmissions so that plays into the "will it fit" calculation when operating the Way-back machine for these trucks.
Old Aug 27, 2020 | 08:36 PM
FuzzFace2's Avatar
FuzzFace2
Yes but the OP was talking 428 car motor into his truck.
Dave ----
Old Aug 27, 2020 | 11:31 PM
85e150's Avatar
85e150
429, to which a ZF from a 460 will bolt up.
ETurner34
Apr 21, 2016 09:50 PM
jzzzake
26
May 26, 2015 06:41 PM
pipman76
Feb 21, 2010 04:13 PM
roger dowty
1978 - 1996 Big Bronco
Mar 23, 2009 11:57 AM
