Fuse keeps blowing
Old Aug 25, 2020 | 04:41 PM
marshall jarvis's Avatar
marshall jarvis
Fuse keeps blowing
I have a 97 Ford F-350 7.3 and the #6 fuse blows instantly when I turn the key on I’ve looked over the wiring harness and haven’t found anything wrong. I did notice that when I unplugged the selector switch in the dash it doesn’t blow the fuse, it only blows when that switch is plugged in. Any ideas?
Old Aug 25, 2020 | 05:32 PM
seville009's Avatar
seville009
Try a new switch maybe? What switch - 4wd?
Old Aug 25, 2020 | 05:37 PM
farmert's Avatar
farmert
The fuel selector valve may have shorted out. Try unplugging the valve, located in the drivers side frame rail just behind the cab.
Old Aug 26, 2020 | 10:30 AM
Hit Man X's Avatar
Hit Man X
Thumbs up
No 6 under hood or in the cab?
Since you discuss the fuel selector, I will assume in cab...A/C clutch is also on this, does this remain working?
lostislandguy
15
Mar 8, 2023 01:04 PM
Waterwise
Jul 18, 2017 12:40 AM
BretE
May 28, 2012 11:17 AM
dtperformance
Nov 11, 2011 09:10 PM
renchr56
Mar 11, 2006 03:07 PM
