ECU 460
Old Aug 25, 2020 | 03:27 PM
Bronco350's Avatar
Bronco350
ECU 460
‘94 Cali460/E4OD in a ‘94 Bronco
Im swapping out the auto for a ZF. Previous owner used same ECU from the stock 5.0 and sent it to a tuner shop to change the firing order and air/fuel settings so it will run the 460. I talked to that same shop and I was told I do not need to do anything different with the ECU to make it run properly with a manual transmission. Maybe I might need to send it out to turn off the “auto function” of the ECU? This information seems contradictory to being told I’ll need to locate a unicorn ECU from a stock MAF 460/ZF5.
What do I need to know about the ECU/wires/sensors to do a successful ZF swap? I would like to keep everything OEM if possible. I doubt I’ll find an ECU for a MAF 460/ZF5. It would be better, I think, if this current ECU will work.
Old Aug 26, 2020 | 09:38 AM
jas88's Avatar
jas88
It will work but, if you pull codes, you will about 8 of them from the ECU griping because the trans is not talking to it.
Old Aug 26, 2020 | 07:35 PM
Bronco350's Avatar
Bronco350
So it’ll perform as should except I’ll have a check engine light on? I can live with that but not for long. Currently, my check engine light is off and I like it that way. If it is on while I ignore it, I won’t know when a new issue comes up. If I were to fix it so that the check engine light goes off awhile after the swap, what would I need to do? I’m convinced I can start the swap any time and drive it afterwards, but I would like to clear the codes at some point, maybe soon, maybe in a year or two.
Old Aug 28, 2020 | 08:39 AM
jas88's Avatar
jas88
It won't turn on the CEL.
Old Sep 8, 2020 | 01:35 PM
Bronco350's Avatar
Bronco350
What about the reverse light? Will the reverse light still work after the manual swap or will I need to figure that out before I start the swap?
Old Sep 9, 2020 | 08:31 AM
jas88's Avatar
jas88
Yes if you use the trans wiring harness from the donor truck.
DeathRangerofDeath
23
Jan 21, 2016 01:48 PM
fordinmudd
Jul 31, 2005 09:20 PM
rscapri
Mar 3, 2004 04:51 PM
Fordzzzz77
Jul 29, 2002 05:42 AM
