Headlight help
Old Aug 25, 2020 | 11:18 AM
77ford250's Avatar
77ford250
Headlight help
I have a 1977 Ford F-250 and I have the factory headlights so I want to get a aftermarket headlights but I don’t know what will fit? I have heard some jeeps headlights will work
thank you
Old Aug 25, 2020 | 11:28 AM
84espy's Avatar
84espy
thank you
What style headlights are you referring to?
Old Aug 25, 2020 | 11:31 AM
77ford250's Avatar
77ford250
I’m sorry if my sentence didn’t make sense I was in a rush typing that out but I have seen these style headlights on a lot of older trucks so I was wondering which halo headlights will fit in my 77 ford truck
Old Aug 25, 2020 | 11:39 AM
ranger140892's Avatar
ranger140892
Grumpy goat
Yeah, any of the 7" round headlights, like Jeep or Harley Davidson, will work. I've got projectors on mine and love them. Get one of the upgraded headlight wiring harnesses from LMC or other supplier. Your old wiring is most likely impeding power. Those harnesses are vehicle specific, cheap, and they're plug & play. The harness is a must imo.
Old Aug 25, 2020 | 11:41 AM
77ford250's Avatar
77ford250
sweet thank you! I do have a new wiring harness in the truck it’s from painless will I still need to get the upgraded wiring?
Old Aug 25, 2020 | 11:53 AM
Lrrr-RulerOfOmicronP's Avatar
You will want to make sure they are DOT approved or you can receive a ticket. Even worse, you could be lumped in with the mall crawler jeeps that blind people with cheap headlights that do not light up the road well but do blind oncoming traffic...
Old Aug 25, 2020 | 12:02 PM
ford390gashog's Avatar
ford390gashog
The Morimoto 2.0 led lights are some of the nicest in the category and have a very defined cut off and DOT approval. I have them on my 68.
Old Aug 25, 2020 | 12:08 PM
77ford250's Avatar
77ford250
where are good places to buy the halos
Old Aug 25, 2020 | 12:09 PM
ranger140892
Grumpy goat
If the Painless wiring harness routes power to the headlights the same way as the OEM harness, I'd upgrade. The advantage to the upgrade harness, is that it draws power directly from the battery. That harness has it's own two relays, Lo & Hi beam. When I first installed mine, I still had incandescent headlights. Those headlights went from dim yellow to bright white after the harness install.
When you get the upgrade harness, you may be surprised by how simple it is. I giggled, because I already had everything I needed to make it myself, it'd had just never occurred to me to make one. But for the price, I was just as happy buying it. Since then, I assembled my own harness for my 2001 Dodge truck.
Old Aug 25, 2020 | 12:16 PM
XSoph's Avatar
XSoph
JW Speaker also makes headlights that will fit our trucks. Good quality from what I have read. I'll be getting their rectangular type for my 78 once the wiring is up to par.
Old Aug 25, 2020 | 12:20 PM
HoustonDave's Avatar
HoustonDave
77ford250 - did the painless harness duplicate the factory harness? Or does it have separate headlight relays added? If the latter, you are good to go.
The original harness ran the main headlight current through the headlight switch, dimmer switch, and if there is any extra resistance in the switches or wires, the headlights do not get full current or shine as brightly. The LMC-type harnesses add relays so the headlight current is only used to trip an added relay, through which full battery power is fed to the lights. Hopefully you understand how a relay works; if not, think of a relay as two switches, one for lots of power and one for little power, hooked together so that little current is needed on the smaller switch to trip the larger switch with lots of power. Like your starter solenoid works, right? Alternatively you can make your own relay harness, costs about $15 and there are multiple forum posts on how to do it. Me, I found a small fuse box on Amazon. I bridged across all the inputs and ran an 8 gauge feed to the battery, giving me 5 fused outputs which are run to relays for low beam headlights, high beam headlights, horn, and an alarm system so I still have an open spare.
Old Aug 25, 2020 | 12:22 PM
77ford250's Avatar
77ford250
do you have the part number for the wiring harness?
Old Aug 25, 2020 | 12:25 PM
ranger140892
Grumpy goat
https://shop.broncograveyard.com/197...ctinfo/24800H/
Old Aug 25, 2020 | 12:28 PM
77ford250's Avatar
77ford250
These are my fuses on the painless wiring diagram if that answers your question
Old Aug 25, 2020 | 12:30 PM
ranger140892
Grumpy goat
You'll be impressed with the improvement you get from the upgrade harness. For giggles, install the harness before you install the LED lights. Compare your incandescent headlights before and after. That $40 goes a long way.
