87 flareside project
Old Aug 24, 2020 | 10:17 PM
KnfMkAR's Avatar
KnfMkAR
Well, my son went ahead and got it - a 87 F150 flareside with a 302 and C6. Currently it starts and idles but when you put it in gear it dies. He replaced the fuel filter - and that helped smooth out the engine. His uncle (my BIL) says it might be the ignition in the column getting moved when the shift selector is moved. So we are looking at that next. Anyone else been down this road?
Old Aug 24, 2020 | 11:38 PM
TooManyMIce's Avatar
TooManyMIce
If you give it a little gas, can you keep it running when it goes into gear, or does it die like the ignition was turned off? Maybe jack up the rear end so going into gear isn't actually loading the engine (much), and if that still kills it, your BIL may be correct. If giving it a little gas keeps it going, I'd check the idle control.
Old Aug 27, 2020 | 09:54 AM
KnfMkAR's Avatar
KnfMkAR
Does regardless of giving it more gas. Going to look into replacing the ignition.
Old Aug 27, 2020 | 09:55 AM
KnfMkAR's Avatar
KnfMkAR
But it’s a good idea to jack up the rear. I’ll try that.
Old Aug 27, 2020 | 07:18 PM
KnfMkAR's Avatar
KnfMkAR
I held the ignition in place while putting it in drive. Worked. Off to the parts store and then YouTube to find a video.
Old Aug 27, 2020 | 10:49 PM
TooManyMIce
Sounds like you got it! Good luck with the column.
Highboy46
Aug 12, 2023 12:16 PM
gatormccluskey
13
Oct 10, 2011 04:43 AM
smelser125
Apr 1, 2007 07:54 AM
msmmce1
Jul 23, 2005 10:25 AM
Supercab
Mar 14, 2001 09:51 PM
