Help. Electrical Problem
Old Aug 24, 2020 | 11:53 AM
DawgMach1's Avatar
DawgMach1
6th Gear
I'm hoping someone here can help me diagnose the problem. I searched the forum and didn't find a match.
Background info - 2004 Excursion - 6.8 V10 - Eddie Bauer Edition 4X4 - No changes/repairs in months - Battery and Alternator replaced about 12 months ago - No electrical issues until now. No hard acceleration or braking involved. Excursion is garage kept and stays out of heat/weather when not being driven.
It started a couple of days ago, randomly at both low speed and highway speeds. The ABS light appears and the AC blower slows down. After a minute or two, the ABS light turns off and the AC blower returns to normal. Today, at low speed, the ABS light appeared and stayed on. Within about 3 to 4 minutes, the headlights flickered, engine surged/loss of power, windows/door locks/radio quit working. I nursed it home and parked. Engine running at idle, no electrical components (other than gauges) seemed to work right. After about 10 minutes, the ABS light turned off and all electrical components worked fine, no issues.
Thanks in advance.
Old Aug 24, 2020 | 08:57 PM
2002Ex's Avatar
2002Ex
Check your grounds, especially around your new components.
Old Aug 25, 2020 | 08:33 AM
DawgMach1's Avatar
DawgMach1
6th Gear
Problem solved. Feedback from Ford Forums pointed to a bad voltage regulator on the alternator. Swapped out the alternator with a new one and problem solved. Cheers!
Old Aug 26, 2020 | 05:58 PM
JSPEX's Avatar
JSPEX
Reading your initial post that's what I was thinking was voltage regulator. Then scrolled down and saw you got it sorted out. Good deal.
nm1sks
Modular V10 (6.8l)
May 1, 2021 09:58 AM
DawgMach1
Aug 28, 2020 09:05 PM
BIGBAND39
Escape & Escape Hybrid
39
Mar 24, 2016 12:23 PM
davebar
May 29, 2007 12:33 AM
jrpoland
Oct 29, 2006 03:08 PM
