Wheel bore size
Old Aug 17, 2020 | 10:27 PM
Sixtfour's Avatar
Sixtfour
Wheel bore size
1964 f100 2 wheel drive, original drum brakes.
im not sure of the wheel bore size on my truck. Would anyone know what it is? I did search for a bit, but came up empty.
is it safe to assume that if the wheel manufacturer is selling 5 x 5.5 bolt pattern wheels that it’s made for Ford truck and will just fit?
I see 4.250, I see 3.250. I also see 83 and 87mm.
Please excuse my wording, should I have used center Bore Diameter? The wheels I am looking at are a bore size of 87.10 mm
Old Aug 18, 2020 | 01:55 AM
Christmas's Avatar
Christmas
Correct me if I'm wrong, but the lug nuts hold the wheel on. I am not aware of wheels that are hub specific.
Old Aug 18, 2020 | 04:11 AM
Crop Duster's Avatar
Crop Duster
I believe the Ford truck center bore is 3 inch. It's hard to find wheels that are made specifically for Fords. Most of the aftermarket wheels have Dodge center hole size and it is a lot bigger. Rocket Racing and a few others make wheels that actually fit the way they are supposed to. It doesn't make that much difference if you have steel wheels and hub caps or center caps to hide the mismatch but if you are running bare wheels it looks a little rednecky with those big Dodge size holes. Also you loose the extra support of having the center hole the correct size.
Old Aug 18, 2020 | 10:34 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
5 lug wheels on a 5.50" bolt circle:
1940/48 Ford/Merc Passenger Cars / 1948/52 F1 / 1953/79 F100 / 1966/96 Bronco / 1969/74 E200 / 1975/96 F150 / 1975/2013 E100/150 / Some 1980/83 F100.
Some 1980/83 F100's have 5 lug wheels on a 4.50" bolt circle.
1940/65 and some 1966 wheels are "innies." Some 1966 and all 1967 and later wheels are "outies."
shermy452
Aug 11, 2015 09:41 AM
BarryMc
May 8, 2008 01:25 AM
cpt.phil
Nov 9, 2007 10:01 AM
Matt66
May 27, 2006 07:35 AM
X5-452
Bronco II
Jun 27, 2003 07:42 PM
