New Oil Cooler
Old Aug 16, 2020 | 03:14 PM
Eric Kropp's Avatar
Eric Kropp
New Oil Cooler
Hi,
Just doing a "backyard rebuild" on a 7.3 IDI. Thinking I'd replace the oil cooler as a precaution. I see them from about $150.00 to $400.00. Should I go with the lower priced one or are they junk.
Thanks!
Old Aug 16, 2020 | 04:46 PM
genscripter's Avatar
genscripter
Unless your system was leaking, I'd keep your original oil cooler. New orings and gaskets would be a prudent investment though.
If you are worried about your oil cooler having a leak, you could use my DIY cooler tester method: https://www.nickpisca.com/diesel/eng...essure-tester/
Old Aug 16, 2020 | 04:47 PM
genscripter
When you replace the orings,, don't cut them by forcing the headers on. Here's a video explaining what I mean:
Old Aug 16, 2020 | 05:59 PM
Eric Kropp's Avatar
Eric Kropp
Yeah,
It's more about not wanting to assemble a leak into my rebuild. I don't have any history on this particular engine or oil cooler. If I assemble the engine and find I have coolant in the oil I won't know if it is the heads or the cooler. Just thinking it could eliminate some questions by installing a new one.
Old Aug 17, 2020 | 12:49 AM
genscripter
Originally Posted by Eric Kropp
Yeah,
99 out of 100 times, oil in the coolant comes from a leaky Oil Cooler. A while back, I had the misfortune of being the 1 out of a 100 that had a cracked block leading to my oil-in-coolant issue. I replaced everything hoping it wasn't the block. in the end, the only thing that fixed it was a rebuild 7.3.
I'd have to wager it's more likely to have coolant in the crankcase from a cracked block or HG.
Old Aug 17, 2020 | 07:56 AM
Eric Kropp's Avatar
Eric Kropp
So assuming I do choose to get a new Oil Cooler.........what are your thoughts of the lower priced ones compared to the more expensive ones?
Old Aug 17, 2020 | 04:44 PM
jjqllc's Avatar
jjqllc
Don't worry, and just get the rebuild kit. I was hesitant about doing mine, but re sealing is the easy part. Getting it in and out while it's in the truck is the hassle.
Old Aug 17, 2020 | 05:13 PM
ford390gashog's Avatar
ford390gashog
Very few options out there for new IDI oil coolers, lots of cheap ones available for Powerstrokes. This is the one Ihave used in two different trucks with good results. I didn't use the included o rings I sourced the o rings and header gaskets from IH.
https://www.ebay.com/i/174329816088?...DefaultOrganic
Old Aug 17, 2020 | 05:23 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
IF you insist on replacing it use an OEM replacement stay away from Dorman they are substandard IMHO
Personally I always just hot tanked them and pressure check and NDI on the end caps and call em good.... be sure there is no pitting on the 'O' Ring Lands that also goes for the Aluminum Headers too.
Old Aug 17, 2020 | 08:17 PM
DarkOverCast's Avatar
DarkOverCast
The 6.9/7.3idi, 7.3 powerstroke, and dt466 all use the same oil cooler tube. The idi turbo and powerstroke/dt466 ones have more internal tubes but that's the only difference other than the end caps.
Old Aug 18, 2020 | 12:13 AM
Charmalu's Avatar
Charmalu
The IDI and Power Stroke look similar, but are not the same.
They will not interchange. When I replaced mine I did a lot of
searching. PS were cheaper at that time but not listed for a IDI.
Parts Geek and Rock Auto had a Motor Craft remanufactured
one at that time, can`t find one now. Both in the $300 range,
don`t remember who I went with, but there were no gaskets or
O Rings in the box when it came. Contacted them and they said
the picture was a generic one, but were were on their listing.
So then I had to search to find the parts, which ended up costing
more.
I used Diesel Hub`s tutorial as a guide.
https://www.dieselhub.com/maintenanc...il-cooler.html
The 4 bolts on the front end are a challenge to get to. I finally
pulled the L/F wheel, inner fender, Battery, coolant bottle etc...
then the bolts are looking right at you. Little more work, but
then 30 years of grit. grime dirt and etc... got cleaned up puttin
it all back together.
I are an expert now after doing one. I agree oil in the coolant
bottle and Radiator are a indicator of a OC Leaking.
It`s the flushing of the cooling system that will take a lot of time.
Charlie
Old Aug 18, 2020 | 10:18 AM
genscripter
IIRC, the PSD oil cooler is 1/4" longer than the IDI. Won't work.
Mich6.0
Jul 8, 2020 05:41 PM
Knox
Aug 22, 2011 09:09 PM
bucky7
Jan 19, 2011 08:20 PM
High Binder
Oct 21, 2010 08:19 PM
TreeFarmer05
Dec 21, 2005 05:17 PM
