Can’t get my timing to align with pointer.
Old Aug 17, 2020 | 08:44 PM
Latchman44's Avatar
Latchman44
Pulley Groove
My 1951 M3 also has the pulley groove.
Might be "normal" for Canadian trucks.
Old Aug 17, 2020 | 09:02 PM
Scott M-47's Avatar
Scott M-47
Good to know!
It must be a Canadian spec for whatever reason.
One last question - after I hooked up the vac advance at idle I noticed timing moved a degree or so more advanced I’m assuming this is normal?
Old Aug 17, 2020 | 10:38 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Yes, completely normal.
Old Aug 21, 2020 | 03:33 PM
KirkF's Avatar
KirkF
It should be noted that there are two different positions for the pointer on the timing covers. This can be seen if you have the timing cover off. There is two possible holes that pointer could have been put in.
If you have the wrong timing cover, your pointer will always be wrong.
Kirk
Old Aug 21, 2020 | 10:33 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Kirk
The two positions are at the same number of degrees, but at different diameters to allow one cover to be used for both Cars and Trucks. Cars used smaller diameter pulleys.
Old Aug 21, 2020 | 10:45 PM
KirkF's Avatar
KirkF
It was my impression that when using the incorrect timing cover, you get 3 or 4 degrees of error on the pointer. However if you have one available to check it with against narrow and wide belt pulleys I will certainly believe you!
Kirk
davemcnitt
Jul 4, 2023 05:59 PM
stevieweevie
Oct 7, 2022 01:43 PM
oldvanner
Mar 13, 2016 10:01 AM
wantaford
Jun 11, 2007 01:55 PM
1950ford
Flathead V8 & Flathead 6
Sep 5, 2005 09:10 PM
