Cut my front valance
Old Aug 15, 2020 | 05:03 PM
VA13FX4's Avatar
VA13FX4
I was about to order the 2wd valance and decided to see what it would look like if I just trimmed the one one there a bit. I think it came out pretty good. Measure twice, and a third and forth time, and cut once. Masked off the line and used a jigsaw. A couple of wavy spots I noticed after the picture where my hand wasn’t too steady were easily taken care of with a sanding block. I’ve just always thought the valance was way too big.
Old Aug 15, 2020 | 05:08 PM
h20camper's Avatar
h20camper
Nice work.
Old Aug 15, 2020 | 05:14 PM
PentaPop's Avatar
PentaPop
Looks good. How many inches did you take off? I need to hack mine too. When I try to roll under there on a creeper, my belly..err....I mean my chest, is too big to fit under that thing!
Old Aug 15, 2020 | 05:20 PM
T. Banning's Avatar
T. Banning
What year is your truck?
Old Aug 15, 2020 | 05:21 PM
cpobst's Avatar
cpobst
That looks so much better. It's on my to-do list. Did you remove it when you cut it?
Old Aug 15, 2020 | 05:41 PM
Lin19687's Avatar
Lin19687
Veteran: Navy
With it shorter it looks like it is Smiling
Old Aug 15, 2020 | 07:03 PM
xxxsherpa's Avatar
xxxsherpa
Did you remove the Prius brackets also?
Old Aug 15, 2020 | 07:35 PM
PA.GRIZZLY's Avatar
PA.GRIZZLY
Looks good.
Old Aug 15, 2020 | 07:47 PM
Mainebucks's Avatar
Mainebucks
Why not just remove it and put nothing back on?
Old Aug 15, 2020 | 07:51 PM
mattymax's Avatar
mattymax
Because it’s not a nice finished edge.
Old Aug 15, 2020 | 07:54 PM
Mainebucks's Avatar
Mainebucks
Thank you. I was thinking that might be the case. Shorter one definitely looks nicer. Will try to cut mine like that when I get my truck in.
Old Aug 15, 2020 | 07:57 PM
Mainebucks's Avatar
Mainebucks
Did you cut it right on the truck, or did you take it off to cut it?
Old Aug 15, 2020 | 07:59 PM
VA13FX4's Avatar
VA13FX4
i basically cut it right above the curved part all the way around. I measured at various points from the bumper down to ensure an even cut. It’s shorter on the ends than the middle. If you want the measurements I can get them tomorrow.
2017. Built Feb 2017.
I left it on because I used the distance from the bumper down to make the line to cut. And I figured it would try to flex around more off the truck while cutting. After I cut it about 1/4 of the way I put tape on it to hold it up, and again at 1/2 & 3/4 because I was worried that it would crack if it was hanging while I cut it.
I did. The jigsaw blade would have hit it. If a Prius finds its way under there it’s gonna be a bad day for everyone, regardless of if those little brackets were there or not. I also zip tied the wiring harness up a bit to make sure it was out of the way.
Old Aug 15, 2020 | 08:02 PM
OffBalance's Avatar
OffBalance
As the owner of two Priuses, I'm terrified of all these modified valance trucks running around without Prius catchers!!!!
VA13FX4's Avatar
VA13FX4
I saw another user that took it off completely, and the underside of the bumper is not finished.
yeah, I just figured it would be easier to cut with the truck holding it for me.
