Manual shift question
Old Aug 15, 2020 | 04:06 PM
nddragon01's Avatar
nddragon01
Using the manual shift option, do you guys typically downshift all the way to 1st when stopping, or do you let the truck downshift on its own? Is there a pro / con to either method, like more or less wear on the trans, or does it not matter which way it's done? My first time with an "auto with manual option" vehicle.
Old Aug 15, 2020 | 04:55 PM
Tom's Avatar
Tom
The short answer is "the truck doesn't care".
The transmission your truck is controlled electronically, so nothing is done inside that case that isn't commanded by the computer. You'll notice and will let you start out in any gear higher than 3rd, and it won't let you downshift into a low gear at a speed that would over rev the engine. There is nothing you can do with those shifting buttons that will hurt the transmission, engine, or anything else.
Old Aug 15, 2020 | 06:23 PM
GlueGuy's Avatar
GlueGuy
+1. If you do something stupid (e.g. shifting down at too high a speed), the transmission computer will not do the shift.
Old Aug 15, 2020 | 06:33 PM
nddragon01's Avatar
nddragon01
Awesome, thanks guys. Some of the downshifts feel rather forceful, so wanted to be sure it was just forceful on me (which I actually don't mind) and not forceful on the trans or engine. Thanks for putting me at ease.
pkenn7
6.7L Power Stroke Diesel
Apr 1, 2011 07:32 PM
powerram50
Oct 8, 2009 12:23 PM
z 97ford1
1997 - 2003 F150
Nov 3, 2006 06:53 AM
jettfuel
Jan 23, 2003 02:27 PM
