1978 Steering wheel replacement
Old Aug 14, 2020 | 09:46 PM
Ace Zoot's Avatar
Ace Zoot
Hello all. My 1968 F100 has a 1978 steering column (ps). I wanted power steering so I went to a junk yard many years ago and was told it was a 1972 and put it in. So now I am replacing the turn signal and would love to find a better steering wheel and horn bar to fix it up until I find a 1968 column to make it right. so far no luck on finding anything. Has anyone else found a one or a replacement? this is what I get for swapping it when I was young.
Not looking for a generic aftermarket wheel. those I can find. Looking for Ford or Ford replacement. LMC just laughed at me when i asked.
Thanks all
Old Aug 15, 2020 | 07:11 AM
72rtchallenger's Avatar
72rtchallenger
Old Aug 15, 2020 | 11:05 AM
benbuilder's Avatar
benbuilder
I have a few 78-79 steering wheels. Email me at chircolandinc@gmail.com
Old Aug 15, 2020 | 11:12 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Ace Zoot
My 1968 F100 has a 1978 steering column (ps). I wanted power steering so I went to a junk yard many years ago and was told it was a 1972 and put it in. So now I am replacing the turn signal and would love to find a better steering wheel and horn bar to fix it up until I find a 1968 column to make it right. So far no luck on finding anything. Has anyone else found a one or a replacement? this is what I get for swapping it when I was young.
P/S steering wheel is the same: 1978/86 F100/350, Econoline and Bronco. 1980/86's use different horn pads than 1978/79.
Same 17" 3 spoke steering wheel: 1960/63 Falcon/Comet // 1961/66 F100/250 2WD // 1966 F100 4WD // 1966/73 Bronco // 1967/70 F100/250 2WD/4WD // 1969/70 F350.
1972/77 F100/350, 1974/77 Bronco, 1975/77 Econoline use the same 2 spoke steering wheel and horn pads except 1975/77 F100/350 & Econoline with Speed Control.
Old Aug 15, 2020 | 11:33 PM
Ace Zoot's Avatar
Ace Zoot
Thanks for the info . I will be able to refine my search now. I did not know there was such a wide range on the 2 spoke wheel.
I wish someone made a reproduction like LMC.
Thank you both.
Old Aug 15, 2020 | 11:43 PM
NumberDummy
Thank you both.
Carpenter reproduces the 3 spoke steering wheel and at one time reproduced the 1971/77 2 spoke steering wheel. You'll have to look to see if he still does.
Most of the repro parts sellers buy parts from Carpenter. Some don't reproduce much of anything.
Old Aug 16, 2020 | 12:56 AM
Ace Zoot's Avatar
Ace Zoot
Bill, so a 1974 - 77 ford bronco 2 spoke looks the same as my 1978 steering wheel? I found one on a Bronco web site (Manufacturer Part NumberD4TZ-3600-A) . I dont want to get it and it not be the same even if it fits.
Thanks
Old Aug 16, 2020 | 01:01 AM
Ace Zoot's Avatar
Ace Zoot
Carpenter has this:
Steering Wheel - 2 Spoke - 1971-77 Ford Truck, 1975-77 Ford Bronco
Part #: D4TZ-3600-A
That the one? Dont mean to bug you. thanks for your input.
Old Aug 16, 2020 | 01:16 AM
NumberDummy
Carpenter has this:
Part #: D4TZ-3600-A
That's it. 1971/73 steering wheels were available in colors. In 1974, Ford obsoleted them replaced them with a black steering wheel: D4TZ-3600-A
Same wheel used thru 1977 except 1975/77's with Speed Control.
btw: It's 1974/77 Bronco and 1975/77 Econoline.
Old Aug 16, 2020 | 03:00 PM
Ace Zoot's Avatar
Ace Zoot
Thanks Bill. your post are always helpful and quick.
I was worried about the horn. just bought a 78 turn signal switch and was wondering if it would work with the 74 bronco wheel. I will need to take a close look at both to see how they fit together. My 78 wheel has a metal strip under the horn pad and the Bronco does not.
Thanks to your info I have a place to look.
Thanks
Old Aug 16, 2020 | 04:06 PM
NumberDummy
1973/77's use different T/S switches than 1978/79.
Old Aug 16, 2020 | 09:01 PM
Ace Zoot's Avatar
Ace Zoot
well darn..... kinda figured that but I was hoping.....Maybe I can return them and go all 74 bronco wheel horn button and TS switch..
Thanks Bill
Ace Zoot
Jun 30, 2020 09:16 PM
Grey Beard
Apr 16, 2020 09:18 AM
Rainmaker1
Jan 11, 2020 10:31 PM
J1MMY
Apr 16, 2009 01:27 PM
Enzo500
15
Jun 14, 2007 11:39 AM
