Sagging front end
Old Aug 13, 2020 | 07:55 AM
Horsethief's Avatar
Horsethief
Sagging front end
Howdy all. So my 73 2wd f100 is slightly saggy on the front pass side, and have a few questions. First, how do I tell what's causing it? Compressed spring, bent I beam, bent axle? , and second, how do I know what size spring to buy (if it's the sprung). Truck has a lift with aftermarket beams. But have no clue how much. I assume it's a 4 inch lift, with a 3 inch body lift from the measurements I have taken. Camber is starting to eat the new tire, so I need to figure this out, but have no clue
Old Aug 13, 2020 | 10:26 PM
niko20's Avatar
niko20
My truck sags on the right as well. Measure from ground to the frame on left and right. That will tell you if it's suspension like beams or a bent frame. . Then measure from knuckle to body. Knuckle to body distance being short is most likely a sagging spring. For me ,f now just put in a few spring lifts (those metal chunk lifts you twist into place) until I get around to buying new springs.
mitchgordon96
Jul 28, 2014 08:52 PM
dillinewton
18
Jan 24, 2010 08:18 PM
th0mpson182
1978 - 1996 Big Bronco
Nov 25, 2003 04:57 PM
lovinspeed01
Offroad & 4x4
Jul 18, 2003 01:27 PM
Janimal
Jun 30, 2003 06:16 PM
