'58 f100 stalling/surging problem
Old Aug 12, 2020 | 11:40 PM
Rainer1945's Avatar
Rainer1945
Hello
I swapped out my generator for an alternator on my 6 cylinder 1958 F100 panel truck and retained the original coil and ballast resistor and ignition points. After several miles on the freeway the car loses power as if running out of gas. Not sure if it's a carburetor issue or fuel tank issue. I had the carburetor rebuilt twice and had the fuel tank cleaned out. Any ideas?
Thanks in advance
Rainer
Old Aug 13, 2020 | 03:33 AM
oldbleu's Avatar
oldbleu
Vapor lock? Is the fuel line running close to any hot exhaust parts? Is the coil breaking down when it gets hot? Is your alternator putting out 13.8 volts after things get hot under the hood? This is my favorite: Is there a proper vent on your gas tank or cap?
Just throwing out a few ideas to sort through.............
Old Aug 13, 2020 | 04:20 AM
Red60's Avatar
Red60
Originally Posted by Rainer1945
Hello
Thanks in advance
Rainer
partially plugged fuel filter will starve the motor during higher flows on the freeway. Also double check float level is correct on the carb.
Old Aug 13, 2020 | 01:16 PM
Rainer1945's Avatar
Rainer1945
I did have vapor lock initially and yes the fuel filter is next to the exhaust manifold. I will re route it and I have a vented gas cap. Thank you for the suggestions.
Old Aug 13, 2020 | 01:17 PM
Rainer1945's Avatar
Rainer1945
Hello
I will definitely do that. Thank you!
Old Aug 14, 2020 | 06:37 AM
grapp's Avatar
grapp
It could be a number of things with a bunch of stuff already mentioned and all worth checking out. But I have a question. Did the truck do this before you changed the generator out? If you never had a fuel problem before the gen swap and you drove it at highway speeds often before without this issue, it leads me to believe its electrical.
Old Aug 14, 2020 | 11:47 AM
Rainer1945's Avatar
Rainer1945
What part of the electrical should I check first?
Thank you
Damonj
Nov 20, 2020 08:30 PM
thedemoguy
Jun 24, 2018 07:46 PM
Oldschool2888
WTB - Parts & other
Aug 12, 2015 10:11 PM
ffjake
Sep 17, 2012 03:35 PM
O-Dog
Aug 2, 2011 02:28 PM
