Improving tailgate operation
Old Aug 14, 2020 | 06:47 AM
XSoph's Avatar
XSoph
This is why brakes and steering are getting done on mine. Sure, I could just slap the new motor in and cross my fingers, but.......
Now, how do we solve the "other people" problem?
Old Aug 14, 2020 | 07:00 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Get with a insurance company like Haggerty's that does classic vehicles or get an insurance company that will insure them for the stated value. YOUR stated value, not Kelly Blue book. They might for a pic or 2 and they want it parked in a carport or garage. But no limit on annual mileage. That is how I do it anyway.
Old Aug 14, 2020 | 07:12 AM
XSoph's Avatar
XSoph
Good tip. Been wondering about good insurance.
Old Aug 14, 2020 | 01:43 PM
F-250 restorer's Avatar
F-250 restorer
I only skimmed all the replies, so I probably missed a lot. But, are you aware that the tailgate handle connects to the rods with a piece of plastic? There is a small clip that holds each rod to the handle mechanism.
Old Aug 14, 2020 | 01:47 PM
77&79F250's Avatar
77&79F250
Yes you skimmed it way to fast see post #7 and it was mentioned and a diagram was posted. Past 431C56 can be located at most HELP sections at the auto parts stores. But F250 restorer thanks for the reminder mention. It's the little details that matter, that often get forgotten.
Old Aug 16, 2020 | 09:31 PM
John89's Avatar
John89
I decided to give our mechanism a going over today. I got some new clips from the parts store, but they only had a variety pack with one each for what we need. Luckily I was able to find some I had from over 25 years ago from an 80 Bronco that I used to have. So I can get my 9 bucks back.
My tip is more than likely the clips will need to be replaced. Ours were completely gone. So make sure you have some before you dig in.
Also be careful as the blind nuts behind the latch assemblies on the sides can come loose and fall inside the tailgate. I used some tacky caulk strip to hold them while I got the bolts started and then pulled outwards on the assembly to keep them from spinning while tightening the bolts.
Cleaned and lubed everything, fought the clips and rods for awhile, but now our tailgate closes without having to hold the handle out/pushing in to latch.
The left side doesn't fully engage, but I think that is because our rear cross sill is toast and tailgate sags a little to the passenger side.
Cross sill has been on the list for awhile.
Thanks for the pictures 77&79. They helped alot.
Old Aug 17, 2020 | 11:04 AM
5851a's Avatar
5851a
Originally Posted by niko20
I don't have to lift the handle to close my gate, and it latches on both sides
I don't know what's wrong with your guys gates.
I can close move no problem no lifting of handle required. Just close the gate and give it a shove.
It's all in the maintenance or the lack of by previous owners along with abuse. My truck may look like it's on last legs but everything opens and closes with 2 clicks. It wasn't perfect when I inherited it but with a few adjustments and lubrication. Shop manuals are a wealth of information as far as maintenance. Thanks for the pics of the latch assembly.
Old Aug 17, 2020 | 12:04 PM
meangreen92's Avatar
meangreen92
The nuts were welded to my latch handle assembly.
Old Aug 17, 2020 | 12:15 PM
John89's Avatar
John89
Sorry for the confusion. I guess they should be called the striker assemblies on the sides. The nut plates in the first pic of post 7 is what I was referring to. I must have skipped over that 77&79 mentioned it as well.
thinlizzy
Jun 27, 2020 01:10 PM
Motate455
Oct 9, 2019 12:43 PM
blue351
Nov 27, 2018 05:20 AM
yargnitram
Jul 28, 2018 10:07 AM
ErrorS
1978 - 1996 Big Bronco
Oct 24, 2009 12:23 AM
