Sponsored by: Auxito
Pulley Rattle
Old Aug 12, 2020 | 04:17 PM
Holman52186's Avatar
Holman52186
Pulley Rattle
00 4.2 V6 will an can a power steering pump pulley rattle? I believe that's what this noise is when I turn the wheel it gets 10x quite. I attached a video!
File Type: avi
File Type: mpeg
File Type: mpg
File Type: mov
Last edited by Holman52186; Aug 12, 2020 at 08:44 PM. Reason: I figured it out have a different question
Old Aug 12, 2020 | 09:57 PM
rvpuller's Avatar
rvpuller
Veteran: Coast Guard
Sounds like a bad idler pulley, remove the belt and give them all a spin and if one is bad replace them al
Denny l
Old Aug 12, 2020 | 10:14 PM
Holman52186
Denny l
Can you just replace pulleys Individually?
Old Aug 13, 2020 | 07:01 AM
rvpuller's Avatar
rvpuller
Yes you can but they've all been on there the same amount of time so why take a chance, if one fails the belt will come off and and most likely ruined along with a chance of overheating the motor.
On my 03 F150 I heard one them when bought it so I just ordered a new belt and a new tensioner and idler pulley so it didn't have to worry about it again. I ruined a motor on one of my work trucks because of a failed pully on a 100' day so I've been proactive every sence.
Denny
Old Aug 13, 2020 | 09:25 AM
alloro's Avatar
alloro
That hub sticking out is for the pully puller to grab onto in order to remove the pulley and swap it over to a new pump.
Old Aug 14, 2020 | 12:20 AM
paker's Avatar
paker
Thank you for the explanation.
OP,
My 97 has not even 70k miles, but I have replaced one idler pulley and the belt tensioner from wear. Just FYI.
