I have an 89 E-150 Econoline custom van and need to replace the transmission cooler lines. Does anyone know a source for OEM style replacements? Part numbers?
It is going to be hard to find lines for a econoline. I am not sure but an 89 E150 and a 89 F150 with the same engine and transmissions would have very similar lines. Probably close enough to get you from the transmission up to the front of the engine near the radiator.
Try giving these guys a call https://www.inlinetube.com/pages/pro...31236874802473
Fab may be your only option. Fittings should not be a problem, but be mindful of "tubing" material chosen (Ni-copp, steel, PVC/plastic coated, annealed stainless, hard stainless, rubber, etc) when you have to make bends, flares, etc.
