1995 Explorer
Old Aug 11, 2020 | 09:57 AM
joxci4's Avatar
joxci4
Question 1995 Explorer
Hi all,
Can someone please provide some guidance on how I can test to see if my compressor is bad? I don't want to throw more parts at it without confirming the issue.
- Low and high side static pressure is 50PSI (with vehicle off), and while running and set to max AC the low side is 20-40 and high side is 75-100PSI. Ambient temp at time of measuring was 68 degrees F.
- The compressor cycles on and off rapidly, so at first I thought low side pressure gauge, but that didn't work so now I'm pretty sure it's the compressor??
- What I already did: evacuated the system and it held a vacuum so no leaks. Changed low side pressure gauge and attempted to re-charge it (through low side of course), but when the pressures didn't change from above readings out of fear of over-charging I closed valve.
Thanks all. It's been a while since I've done A/C and I'm rusty.
srwven
17
Jun 18, 2017 01:20 PM
rodneycrow
May 11, 2016 12:10 AM
husker16
19
Jul 26, 2012 05:51 PM
razaka
23
May 8, 2006 01:09 PM
JTSHANNY
Apr 21, 2005 03:16 PM
