MC2150 rebuild
Old Aug 9, 2020 | 04:34 PM
kravenoft78's Avatar
kravenoft78
MC2150 rebuild
Does it matter if I put the EGR spacer plate back on with this? After taking it apart it seems like the EGR was blocked off where it connects to the plate anyhow.
All clean from her bath ready to be assembled! Hope I don’t screw this up!
Old Aug 9, 2020 | 06:36 PM
68Flareside240's Avatar
68Flareside240
I put mine back on, because it didn’t leak and ran good before, and it was one more thing between the intake and carb to absorb heat. Driving this truck in the Alabama heat, it will diesel on shutoff, and boil the fuel out of the bowl even with 87-89 ethanol free. The fuel these trucks were designed for just isn’t available anymore.
Old Aug 11, 2020 | 11:05 AM
barnyard's Avatar
barnyard
i would run it (blocked off) or an equivalent spacer. that way all linkages and hose/line connections fit properly. btw, spacers are good.
Old Aug 12, 2020 | 07:10 AM
CelticOne's Avatar
CelticOne
Regular User
Welcom to FTE!
You will want to either use the EGR plate or a spacer. As stated, these are needed to absorbe heat from the intake or vapour lock can occur.
Post some pictures of your truck. Whatcha got there?
Old Aug 12, 2020 | 03:31 PM
mark a.'s Avatar
mark a.
Your local parts store should have a small freeze plug to drive down into the passage in the manifold to stop the leak. They wont last forever but it's a quick way to plug it and not have to worry about a base gasket leak.
Old Aug 12, 2020 | 09:42 PM
kravenoft78
For now I will just put it back on the way it was. The truck ran & I didn’t know any different. I typically like to fix things that are incorrect, if you will, while I have the components disassembled. Right now I don’t have the time to wait on a new spacer without the egr aspect nor the money to spend on new stuff when the old works! Thank you for the information everyone! Learning a little more everyday!
hankhowi
Ford Truck Parts for Sale
Feb 5, 2018 09:54 PM
bullnose1985
16
Oct 15, 2017 03:04 PM
db9397
Nov 6, 2013 11:59 AM
bradford237
Sep 7, 2012 05:43 PM
Barkin 40s
Aug 9, 2010 09:38 AM
