Glow plugs
Aug 9, 2020 | 03:10 PM
Glow plugs
About a year ago I threw po672 , six months later po673, yesterday po675. As I understand it these are all glow plug related. Truck starts and runs great. I am in south Louisiana so cold weather is not really a problem. Should I go ahead and get these replaced or is it only starting in cold weather related?
Aug 9, 2020 | 06:11 PM
It would bother me knowing there was an issue and not fixing it.
Aug 9, 2020 | 09:10 PM
Quote:
Originally Posted by
xcrsp440
Yeah I know what you mean. I will probably just order some and get it done on a weekend
Aug 9, 2020 | 11:17 PM
They can be a challenge to remove. The harness will break taking it off. Have replacement on hand.
You can ohm them easily to see if it is the gp or the module.
Only use OEM too.
Aug 10, 2020 | 07:38 PM
get new glow plugs and 2 harnesses, like it has been said the harness will break off right above the glow plug
Aug 12, 2020 | 04:24 AM
If you get the plug pulling tool two things that you need to keep in mine.
Make sure that the tool is all the way on the boot and not just the legs.
This is a DiesleTechRon tip. Put a little bend in the tool. Makes it a lot better pulling angle.
Ron shows how he has bent the tool to make is easer to use. Go to about 2:05 into the video.
Aug 13, 2020 | 07:07 PM
put the truck on jack stands and pull the front wheels and remove the fender liner much easier and you can see everything
Aug 13, 2020 | 07:33 PM
That works just fine unless you got factory
fender flares where you cannot remove the
inner wheel well liner because they’re
trapped under the flares.
miranda machining
Mar 23, 2018 05:04 PM
Jordo88
Oct 23, 2016 11:05 AM
RobertJohn
Dec 23, 2013 03:20 PM
klmracing
Dec 15, 2009 07:13 PM
hoodjason
21
Sep 24, 2007 04:34 PM
