E-350 van, Ac stops or gets hot when sitting.
Old Aug 8, 2020 | 09:30 AM
windyhill's Avatar
windyhill
I have a, 06 E-350 Super Duty pass. van. The seams to work ok, but on trips when slowing in traffic it stops working and car gets hot. I checked levels with gauges last year and put a new blower motor in but it didn't help. Trip coming up next week and it needs to work! I've never opened this system up. It has front and rear air, I'm thinking, get it drained, replace the Accumulator / receiver / dryer or dryers (not sure how many I have with the dual air) and recharge? Looking for suggestions.
Old Aug 8, 2020 | 12:28 PM
projectSHO89's Avatar
projectSHO89
Clean your condenser and check the condition/function of your cooling fan operation first.
Old Aug 8, 2020 | 04:24 PM
windyhill's Avatar
windyhill
So condenser looked ok, but I pulled apart the whole box and got into the Evaporator and it was almost completely clogged with wet lint etc.! It's possible to get at without draining system and undoing hoses but not easy. Air blows much better now and cooler. Might need a drain and refill still as it hasn't been done ever I believe.
If someone else is having issues, (not much air coming out of registers even on high) Pull battery, tray, wiper fluid tube etc. remove two bolts on condenser, and undo and remove blower fan. you can then look inside and see how bad yours is and weather you want to dive in deep and deal with it!
Old Aug 8, 2020 | 06:02 PM
projectSHO89
The condenser is in front of the radiator...
Old Aug 8, 2020 | 07:41 PM
windyhill's Avatar
windyhill
Yep, and fan was replaced.
Miketheviking
Mar 29, 2018 09:19 PM
k9dr
21
Aug 28, 2014 06:03 PM
k41184
May 11, 2013 01:25 AM
rjpsr
Jul 24, 2011 03:37 PM
