A/C doesn't blow hard, can't cool cabin
We've just returned from a 2 week vacation pulling an RV in our 2008 F450. During the first week we crossed the Mojave dessert, and about roasted because the A/C barely put out any cool. So we dropped the truck off at the Ford dealer where the 'fixed' the A/C, indicating there was a couple leaks.
The A/C definitely blows cold now, but not very much. Coming home across west Texas, we were still quite uncomfortable in the cabin. The A/C was blowing, but not enough to really cool the cabin down.
My wife drives a 2007 Honda Civic, and the air comes out of those vents quite strongly. For example, you can hold you hand about 3-4 feet away and feel the cool air. On the 'repaired' truck you can barely feel the cool air 1-2 feet. It also doesn't sound like it's blowing nearly as hard.
Is this just the way the 2008 Ford F450 A/C is designed?
-Do you have all (4?) of your fan speeds? Starting at the lowest speed, can you hear the motor speed up as you turn up the speed control?
-Does the truck use a cabin filter? If so, and it's plugged, that will restrict your airflow from the vents
If it's neither one of those, you likely have an evaporator thats plugged externally with dirt, dust, organic matter, etc. All of the air that goes through the air handler flows through that damp, tightly finned evaporator first. Not sure about your 450, but on many vehicles the instrument panel has to be removed to access the evaporator.
Even if the recirc door was stuck in the fresh air position, you should have good airflow.
Listen for a change in the sound of the blower when switching between AC and MAX AC. If it changes at all, it's likely working as it should.
The interior air intake (recirculated air intake) is usually visible above the passenger foot well and you can often see the recirc door through the grille. You may be able to actually see the movement.
Why were those parts replaced and who did that job? Were they experienced or just winging it? Was the re-assembled system properly evacuated, leak tested and charged to its proper refrigerant level?
